[GRASS5] R.flow again
Michael Barton
michael.barton at asu.edu
Tue Dec 6 13:56:48 EST 2005
Moritz,
I tried your suggestion and the script works fine from the command line.
Thanks.
It is a problem somehow with gui.tcl, because that is where the progress bar
code is located, or (more likely) something that gui.tcl runs or interacts
with.
I think the problem is fairly new (last month or 2?). Nothing in gui.tcl
itself has changed that recently. However, I don't know about g_gui() or
g_parser() or other related functions.
I might try redirecting the r.flow output to try to keep it out of the
progress bar loop, but even if successful this is a band aid that doesn't
get to the cause of a problem that affects other modules as well.
Michael
______________________________
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Moritz Lennert <mlennert at club.worldonline.be>
> Date: Tue, 06 Dec 2005 11:55:37 +0100
> To: Michael Barton <michael.barton at asu.edu>
> Cc: grass5 <grass5 at grass.itc.it>
> Subject: Re: [GRASS5] R.flow again
> Michael Barton wrote:
>> OK, now something even stranger is happening with r.flow.
>> I just did a script to create a net erosion/deposition map using USPED.
>> I¹ve tested it on the Spearfish data set. It includes r.flow, running
>> from the CLI of course.
>> If I zoom into to a very small area (205x172), it works like a charm.
>> But if I zoom out a little bit, r.flow bombs with the error below.
>> If I try the same zoom levels with the CLI for r.flow, it works fine.
>> Both are actually running r.flow via the CLI. However, the script is
>> started from a tcltk dialog. Does anyone have any idea what is going on
>> here? This script is nice to automate a tedious set of calculations.
>> Run from script at 479x472 (as above) and r.flow bombs with the
>> following message
>> Opening output files...done.
>> Allocating memory: elevation, aspect, density, e/w distances,
>> quantization tolerances.
>> Reading input files: elevation...
>> Precomputing: tangents, e/w distances, quantization tolerances,
>> interpolated border elevatio
>> ns, aspects.
>> Working...done.
>> Writing density file...WARNING: 'cell/test' was found in more mapsets
>> (also found in user1).
>> done.
>> Closing files...done.
>> De-allocating memory...done.
>> GRASS 6.1.cvs (spearfish60_valencia):~ > r.usped &
> Have you tried running the _script_ from the CLI, i.e. by giving it its
> parameters directly, and not via the tcltk interface ?
> Moritz
