[GRASS5] G_done_msg()
Glynn Clements
glynn at gclements.plus.com
Tue Dec 6 14:01:30 EST 2005
Hamish wrote:
> > I think that GRASS modules talk too much, I would be in favour
> > of reducing messages instead of adding new.
> > Regarding G_done_msg() I believe that exit(0) says the
> > same and it is sufficient. It only depends on GIU around
> > how it interprets the exit status.
> Wasn't there a problem with the way GRASS Tcl code ran the modules,
> where it the window never really knew when the module finished after you
> hit "run"?
[I'll summarise an import point which came up in off-list discussion.]
Unless you redirect the output of a process, it is returned to Tcl by
setting the process' stdout to the writer end of a pipe (with Tcl
keeping the reader end).
If the program spawns children, and allows them to inherit its stdout,
then the output from the children is indistinguishable from the output
from the original program. Consequently, exec won't return until any
children have closed their copy of the write end of the pipe (either
explicitly, or by terminating).
E.g. if you do "exec d.mon start=x0", the return value from exec will
be anything written to stdout by either d.mon, mon.start, or XDRIVER.
IOW, exec will not return until the XDRIVER process terminates.
If you don't want this behaviour (and you probably don't), possible
solutions are:
1. Have the exec command redirect d.mon's stdout to d.m's stdout
(which is probably a terminal), i.e.
exec d.mon start=x0 >@stdout
2. Change mon.start so that XDRIVER doesn't inherit stdout. But then
you won't see any messages from XDRIVER.
3. Change XDRIVER to close its standard descriptors (this is how most
"daemon" programs behave). Again, it can't write diagnostic messages
to stdout or stderr if they have been closed.
Note that this is particularly counter-intuitive when running e.g.
d.resize, which stops the old driver and starts a new one. The new
driver will be a child of whatever called d.resize, and will inherit
its standard descriptors (which may be complete different to those
used by the old driver).
> (why we can't grey-out the "run" button while the module is
> processing)
That should be easy enough to implement.
In run_cmd, add:
$opt($dlg,path).run configure -state disabled
when the command starts successfully, i.e.:
if { $ret } {
error $fh
fconfigure $fh -blocking 0
fileevent $fh readable [list prnout $dlg $fh]
In prnout, add:
$opt($dlg,path).run configure -state normal
when EOF is detected, i.e.:
if [eof $fh] {
close $fh
} else {
