[GRASS5] Re: [GRASSLIST:9356] Re: v.in.ascii problems
Roger Bivand
Roger.Bivand at nhh.no
Wed Dec 7 09:04:08 EST 2005
On Thu, 8 Dec 2005, Hamish wrote:
> > There is an on-going discussion about this on the GRASS development
> > list. >>From a simple test I ran last night, v.in.ascii -b (the -b
> > flag is new in GRASS 6.1 CVS) does not build topology, and this
> > removes one of the two humps in memory consumption. The other hump (>
> > 200MB for a 1M point file with a single attribute) was associated with
> > writing the dbf file (the file is 60MB), and is where things stick
> > now. In addition, the -b flag leaves the vector data set at level 1
> > topology (absent), and almost all vector commands need level 2.
> > I do now know whether the use of a different database driver than the
> > default would help. The dbf writing stage preceeds the topology
> > building, so the two memory-intensive humps are separate, with
> > topology being a little larger. Reading 1M points on a 1.5GHz P4 with
> > topology took about 7 minutes, without about half that time.
> Use the -z and -t flags to avoid making the table. (and the z= option)
> If the input is just x,y,z data there is no need for a table.
For me in an x-y location my data with 1M points and -zbt now read in just
under a minute; lidaratm2.txt in effectively the same time (64 rather than
57 seconds, z here is double not int) and v.in.ascii stays at a
respectable 3.3MB size. d.vect works, but as you say prints a warning.
> At minimum, we need v.info, v.surf.rst, v.univar, v.out.ascii (points)
> and some sort of subsampling module (ie s.cellstats port) working with
> this data. d.vect works already (with a warning). maybe v.surf.idw too.
> Probably not many more modules though? -- I think if Radim doesn't want
> this to be common-place use of the vector model then it probably shouldn't
> be. He knows it better than anyone.. So for now massive point datasets
> need to be treated as a special case to the vector model & only a
> work-around solution.
> e.g. with the sample LIDAR data (GRASS downloads page)
> G61> v.in.ascii -zbt in=lidaratm2.txt out=lidaratm2 x=1 y=2 z=3 fs=,
> The first 250k points take about 20 seconds to load.
> If I use the full million it gets stuck on the scanning step:
> D3/3: row 374430 : 28 chars
> Interesting, that line is the second value with elevation > 100.
> changing the first z value to 500.054 it segfaults pretty quick:
> D5/5: Vect_hist_write()
> D4/5: G_getl2: ->-75.622346,35.949693,500.054<-
> D3/5: row 1 : 28 chars
> D4/5: token: -75.622346
> D4/5: is_latlong north: -75.622346
> D4/5: row 1 col 0: '-75.622346' is_int = 0 is_double = 1
> D4/5: token: 35.949693
> D4/5: is_latlong north: 35.949693
> D4/5: row 1 col 1: '35.949693' is_int = 0 is_double = 1
> D4/5: row 1 col 2: '500.054' is_int = 0 is_double = 1
> D4/5: G_getl2: ->-75.629469,35.949693,11.962<-
> D3/5: row 2 : 27 chars
> D4/5: token: -75.629469
> D4/5: is_latlong north: -75.629469
> D4/5: row 2 col 0: 'H629469' is_int = 0 is_double = 0
> Segmentation fault
> where is 'H629469' coming from?
I was also seeing seg-faults with my data in a long-lat location, so
switched to x-y (current CVS 6.1).
Roger
> v.in.ascii/points.c
> tmp_token is getting corrupted, cascades from there
> int points_analyse (){
> char **tokens;
> tmp_token=(char *) G_malloc(256);
> while (1) {
> tokens = G_tokenize (buf, fs);
> for ( i = 0; i < ntokens; i++ ) {
> [*] sprintf(tmp_token, "%f", northing);
> /* replace current DMS token by decimal degree */
> tokens[i]=tmp_token;
> BOOM. pointer abuse. (bug is new lat/lon scanning code, only in 6.1CVS)
> [*] and if northing column is longer than 256 without hitting the fs,
> buffer overflow?? add ,int maxlength, parameter to G_tokenize()?
> or can %f never be more than 256 bytes long?
> same %f effectively cutting down precision of lat/lon coords to 6
> spots after the decimal place? (be that pretty small on the ground)
> improvements come one bug at a time...
> Hamish
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
