[GRASS5] v.external, OGR/OCI and v.in.ogr
Stephan Holl
holl at gdf-hannover.de
Fri Dec 9 02:26:46 EST 2005
Hello Radim,
On Fri, 2 Dec 2005 10:13:51 +0100 Stephan Holl <holl at gdf-hannover.de>
wrote:
> Hello Radim,
> thanks for the quick response.
> On Fri, 2 Dec 2005 09:38:54 +0100 Radim Blazek
> <radim.blazek at gmail.com> wrote:
> > The problem is obviously missing FID. Try 2 things
> > 1) remove topo file and try to run d.vect
> Yes, after removing the topo-file d.vect shows up the vector-lines,
> but v.info complains about the missing topo-file.
> ERROR: Cannot open old vector roads_OCI at user1 on level 2
> Is this a bug or a feature?
> > 2) try to add FID column (unique id) to the table
> Isnt that the job of v.external when "importing/linking"? AFAIK a
> unique colums is in the table:
> v.db.select roads_OCI|head
> ERROR 1: ORA-00904: "FID": invalid identifier
> in select FID from ROADS_SPEARFISH60_2 where FID > 0
> ERROR 1: ORA-00904: "OGC_FID": invalid identifier
> in select ogc_fid from ROADS_SPEARFISH60_2 where ogc_fid > 0
> Using ogr_fid column in OGR DB
> OGR_FID|cat|label|column3
> 1|5|unimproved road|0
> 1|4|light-duty road, improved surface|0
> GRASS 6.1.cvs (spearfish60):~/spearfish60/user1/vector/roads_OCI >
> Thanks for looking into this.
I cannot understand the above thing about topology-info. In short,
Linked OCI-based dataset with v.external does not show in the display
unless I remove the topo-file. But then nearly no other vector-modules
are working.
Is this a Bug or a feature?!
Best
Stephan
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office - Mengendamm 16d - D-30177 Hannover
Internet: www.gdf-hannover.de - Email: holl at gdf-hannover.de
Phone : ++49-(0)511.39088507 - Fax: ++49-(0)511.39088508
