[GRASS5] v.external, OGR/OCI and v.in.ogr
Radim Blazek radim.blazek at gmail.com
Fri Dec 9 05:49:10 EST 2005
It seems to be a bug in Oracle driver for OGR.
FID is assigned to features by OGR and it is different for
each driver. It has nothing to do with GRASS.
Radim
On 12/9/05, Stephan Holl <holl at gdf-hannover.de> wrote:
> Hello Radim,
> On Fri, 9 Dec 2005 09:15:46 +0100 Radim Blazek <radim.blazek at gmail.com>
> > > I cannot understand the above thing about topology-info. In short,
> > > Linked OCI-based dataset with v.external does not show in the
> > > display unless I remove the topo-file. But then nearly no other
> > > vector-modules are working.
> > > Is this a Bug or a feature?!
> > On level 2 (with topo) the elements are accessed using OGR FID,
> > I have seen in you debug output that all all lines have FID 1.
> > You should check (ogrinfo) if OGR gives unique FID
> > (the number following 'OGRFeature(layer):') for each feature.
> Aha! Here it is! every OGRFeature is 1.
> OGRFeature(ROADS_SPEARFISH60):1
>   cat (Integer) = 4
>   label (String) = light-duty road, improved surface
>   column3 (Integer) = 0
>   LINESTRING (601071.341320500010625 4914275.983005239628255
> 0,601130.543313059955835 4914239.814913230016828
> 0,601199.645887729944661 4914209.641895060427487 0)
>   cat (Integer) = 4
>   LINESTRING (601229.638940269942395 4914208.033029629848897
>   cat (Integer) = 5
>   label (String) = unimproved road
>   LINESTRING (601383.701443820027635 4914490.324604500085115
> 0,601458.067195220035501 4914506.784756160341203
> 0,601565.896428929991089 4914540.368791960179806
> 0,601619.450047809979878 4914568.157080279663205
> 0,601705.821419609943405 4914621.78729119990021
> 0,601777.390685699996538 4914706.498295440338552
> 0,601829.976874400046654 4914804.547851240262389
> 0,601874.278788840048946 4914851.838009960018098
> 0,601905.941478710039519 4914864.842336039990187
> 0,601938.245388729963452 4914871.740031310357153
> 0,601989.454707090044394 4914880.574088539928198
> 0,602015.031405410030857 4914890.490086000412703 0)
> So I have to blame v.out.ogr for not exporting the data
> correctly into oracle?!
> OK, trying to export into shp and import shape into oracle via ogr2ogr:
> v.out.ogr in=roads dsn=/tmp olayer=roads_spearfish_shp
> ogrinfo -al roads_spearfish_shp.shp
> OGRFeature(roads_spearfish_shp):822
>   cat (Real) =           1
>   label (String) = interstate
>   column3 (Real) =           0
>   LINESTRING (608461.963513449998572
> 4924891.454097949899733,608500.583600339945406
> 4924848.395944519899786,608542.302375869941898
> 4924805.986163049936295,608588.929304940043949
> 4924753.627536799758673,608679.141620320035145 4924655.828847349621356)
> OGRFeature(roads_spearfish_shp):823
>   cat (Real) =           3
>   label (String) = secondary highway, hard surface
>   column3 (Real) =           0
>   LINESTRING (608499.937198620056733
> 4924995.604408769868314,608461.963730340008624 4924891.45383136998862)
> OGRFeature(roads_spearfish_shp):824
> Seems to export OK into shp.
> Will now try with ogr2ogr and see what happens then.
> ogr2ogr -f OCI "OCI:holl/pw at ORACLESP" roads_spearfish_shp.shp
> ogrinfo -ro "OCI:holl/n8eulen at ORACLESP" ROADS_SPEARFISH_SHP
> OGRFeature(ROADS_SPEARFISH_SHP):805
>   cat (Integer) = 1
>   LINESTRING (599766.326235549990088 4925326.424210700206459
> 0,599779.949210750055499 4925333.039808190427721
> 0,599819.86159005004447 4925357.376621429808438
> 0,599920.882107450044714 4925416.319270299747586
> 0,599964.417756509967148 4925443.534300420433283
> 0,600159.730849539977498 4925569.802055209875107 0)
> OGRFeature(ROADS_SPEARFISH_SHP):806
>   cat (Integer) = 2
>   label (String) = primary highway, hard surface
>   LINESTRING (600184.343943119980395 4925585.71580228023231
> 0,600169.898571319994517 4925605.305413190275431 0)
> OGRFeature(ROADS_SPEARFISH_SHP):807
>   cat (Integer) = 2
> Seems to be OK as well.
> So I assume that v.out.ogr does not produce unique OGRFeature-numbers
> when Importing directly into Oracle using OCI.
> Can anybody confirm?
> Best
>         Stephan
> GDF Hannover - Solutions for spatial data analysis and remote sensing
> Hannover Office      -     Mengendamm 16d      -     D-30177 Hannover
> Internet: www.gdf-hannover.de      -      Email: holl at gdf-hannover.de
> Phone : ++49-(0)511.39088507       -        Fax: ++49-(0)511.39088508
