[GRASS5] d.vect -a|c for all types ver2
Sun Dec 11 02:03:28 EST 2005
> 2005/10/20, Markus Neteler <neteler at itc.it>:
> > On Tue, Oct 18, 2005 at 07:12:38PM +0200, Markus Neteler wrote:
> > > On Thu, Oct 06, 2005 at 09:18:33AM +0000, Martin Landa wrote:
> > > > Hi all,
> > > > I have rewritten the patch for d.vect which enables to use flags
> > > > -a and -c for all vector types (not only for areas). I hope I
> > > > did it better this time (for previous patch see
> > > > http://grass.itc.it/pipermail/grass5/2005-September/019563.html).
> > Hi Martin,
> > I tested the new d.vect code (the Vlib/area.c fix is in CVS),
> > but there is a bug in d.vect/area.c:
> > d.vect delauney
> > ERROR: Attempt to read topo for dead isle (2)
> > The problem is the line:
> >   if (Vect_get_isle_area(Map, area))
> > Since this function ends with a fatal error for non-island
> > areas, it must be used in a different way.
> > However, for details better ask Radim...
> > I am sure that you'll iron out this missing piece!
> > Markus
> I have tried to solve this problem - I am really not sure, maybe I
> don't understand correctly areas and isles...
> There is a new patch for d.vect... I hope without any huge bugs;-)
> Please test it ... I am ready for your comments.
> Best regards,
> Martin
Is this patch ready to be committed to CVS?
What is the place of "area.diff"? It does not apply cleanly.
Hamish
diff -ru display/d.vect.cvs/area.c display/d.vect/area.c
--- display/d.vect.cvs/area.c	2005-08-09 13:26:59.000000000 +0200
+++ display/d.vect/area.c	2005-10-23 23:57:21.000000000 +0200
@@ -10,31 +10,7 @@
 #include "plot.h"
 #include "colors.h"
 #include "dbmi.h"
-/* TODO: should use 24bit instead of 16 colors, maybe implement
-   predefined color tables? */
-struct rgb_color {
-        unsigned char R, G, B;
-static const int palette_ncolors = 16;
-static struct rgb_color palette[16] =  {
-	{198, 198, 198}, /*  1: light gray */
-	{127, 127, 127}, /*  2: medium/dark gray */
-	{255,   0,   0}, /*  3: bright red */
-	{139,   0,   0}, /*  4: dark red */
-	{  0, 255,   0}, /*  5: bright green */
-	{  0, 139,   0}, /*  6: dark green */
-	{  0,   0, 255}, /*  7: bright blue */
-	{  0,   0, 139}, /*  8: dark blue   */
-	{255, 255,   0}, /*  9: yellow */
-	{139, 126,  10}, /* 10: olivey brown */
-	{255, 165,   0}, /* 11: orange */
-	{255, 192, 203}, /* 12: pink   */
-	{255,   0, 255}, /* 13: magenta */
-	{139,   0, 139}, /* 14: dark magenta */
-	{  0, 255, 255}, /* 15: cyan */
-	{  0, 139, 139}  /* 16: dark cyan */
+#include "glocale.h"
 int darea ( struct Map_info *Map, struct cat_list *Clist, int bcolor, int fcolor,
 	     int chcat, int id_flag, int table_colors_flag, int cats_color_flag, struct Cell_head *window) {
@@ -44,16 +20,16 @@
     struct line_cats *Cats;
     int cat, centroid = 0;
     int red, grn, blu;
+    struct ilist *isles = NULL;
-    struct field_info *fi=NULL;
+    struct field_info *fi = NULL;
     dbDriver *driver = NULL;
-    dbHandle handle;
-    dbString stmt, valstr;
-    dbCursor cursor;
-    dbTable  *table;
-    dbColumn *column;
-    char buf[2000], colorstring[12]; /* RRR:GGG:BBB */
-    int more, ret;
+    dbCatValArray cvarr;
+    dbCatVal *cv_rgb = NULL;
+    int nrec;
+    int i, rgb;  /* 0|1 */
+    char colorstring[12]; /* RRR:GGG:BBB */
     unsigned char which;
     G_debug (1, "display areas:");
@@ -63,28 +39,60 @@
     if( table_colors_flag ) {
       /* for reading RRR:GGG:BBB color strings from table */
-      db_init_string (&stmt);
-      db_init_string (&valstr);
-      fi = Vect_get_field( Map, Clist->field);
-      if ( fi == NULL )   G_fatal_error ("Cannot read field info");
-      driver = db_start_driver(fi->driver);
-      if (driver == NULL) G_fatal_error("Cannot open driver %s", fi->driver);
-      db_init_handle (&handle);
-      db_set_handle (&handle, fi->database, NULL);
-      if (db_open_database(driver, &handle) != DB_OK)
-	  G_fatal_error("Cannot open database %s", fi->database);
+      db_CatValArray_init (&cvarr);
+      fi = Vect_get_field (Map, Clist -> field);
+      if (fi == NULL) {
+	G_fatal_error(_("Cannot read field info"));
+      driver = db_start_driver_open_database(fi->driver, fi->database);
+      if (driver == NULL)
+	G_fatal_error(_("Cannot open database %s by driver %s"), fi->database, fi->driver);
+      nrec = db_select_CatValArray(driver, fi->table, fi->key,
+				   "GRASSRGB", NULL, &cvarr);
+      G_debug (3, "nrec (grassrgb) = %d", nrec);
+      if (cvarr.ctype != DB_C_TYPE_STRING)
+	G_fatal_error (_("Column type (grassrgb) not supported"));
+      if ( nrec < 0 ) G_fatal_error (_("Cannot select data (grassrgb) from table"));
+      G_debug(2, "\n%d records selected from table", nrec);
+      db_close_database_shutdown_driver(driver);
+      for ( i = 0; i < cvarr.n_values; i++ ) {
+	G_debug (4, "cat = %d grassrgb = %d", cvarr.value[i].cat,
+		 db_get_string(cvarr.value[i].val.s));
     num = Vect_get_num_areas(Map);
     G_debug (2, "n_areas = %d", num);
+    /* initialize isles - needed? */
+    isles = Vect_new_list ();
+    for ( area = 1; area <= num; area++ ) {
+      n_isles = Vect_get_area_num_isles ( Map, area );
+      for ( i = 0; i < n_isles; i++) {
+	isle = Vect_get_area_isle ( Map, area, i );
+	if (isle > 0) {
+	  Vect_list_append (isles, isle);
 	int i;
 	BOUND_BOX box;
         G_debug (3, "area = %d", area);
-	if ( !Vect_area_alive (Map, area) ) continue;
+	if ( !Vect_area_alive (Map, area) || Vect_val_in_list(isles, area)) continue;
 	/* Check box */
 	Vect_get_area_box (Map, area, &box);
 	if ( box.N < window->south || box.S > window->north ||
@@ -141,67 +149,90 @@
 	    Vect_append_points ( Points, IPoints, GV_FORWARD);
 	    Vect_append_point ( Points, xl, yl, 0.0 ); /* ??? */
-	     cat=Vect_get_area_cat ( Map, area, Clist->field );
-	     if( cat >= 0 ){
-		G_debug (3, "display area %d, centroid %d, cat %d", area, centroid, cat);
-		/* Read RGB colors from db for current area # */
-		sprintf ( buf, "select %s from %s where %s = %d", "GRASSRGB", fi->table,  fi->key, cat);
-		G_debug (3, "SQL: %s", buf);
-		db_append_string ( &stmt, buf);
-		if (db_open_select_cursor(driver, &stmt, &cursor, DB_SEQUENTIAL) != DB_OK)
-			G_fatal_error ("Cannot select attributes for area # %d.", area);
-		table = db_get_cursor_table (&cursor);
-		column = db_get_table_column(table, 0); /* first column */
-		if(db_fetch (&cursor, DB_NEXT, &more) != DB_OK) continue;
-		db_convert_column_value_to_string (column, &valstr);
-		sprintf (colorstring, "%s", db_get_string(&valstr));
-		/* only draw if GRASSRGB was defined */
-		if (strlen(colorstring) != 0) {
-			G_debug(3, "area centroid %d: colorstring: %s", centroid, colorstring);
-			ret =  G_str_to_color(colorstring, &red, &grn, &blu);
-			if ( ret == 1 ) {
-				R_RGB_color ((unsigned char) red, (unsigned char) grn, (unsigned char) blu);
-				G_debug(3, "area:%d  cat %d r:%d g:%d b:%d", area, cat, red, grn, blu);
-				G_plot_polygon ( Points->x, Points->y, Points->n_points);
-			} else if ( ret == 0 ) { /* error */
-				G_warning("Error in color definition column GRASSRGB, area %d with cat %d: colorstring %s (not drawing this area)", area, cat, colorstring);
-	     } /* end if cat */
+	  cat=Vect_get_area_cat ( Map, area , Clist -> field );
+	  centroid = Vect_get_area_centroid ( Map, area );
+	  if( cat >= 0 ){
+	    G_debug (3, "display area %d, centroid %d, cat %d", area, centroid, cat);
+	    /* Read RGB colors from db for current area # */
+	    if (db_CatValArray_get_value (&cvarr, cat, &cv_rgb) != DB_OK) {
+	      rgb = 0;
+	    else {
+	      sprintf (colorstring, "%s", db_get_string(cv_rgb -> val.s));
+	      if (strlen(colorstring) != 0) {
+		G_debug(3, "area %d: colorstring: %s", area, colorstring);
+		if ( G_str_to_color(colorstring, &red, &grn, &blu) ) {
+		  rgb = 1;
+		  G_debug(3, "area:%d  cat %d r:%d g:%d b:%d", area, cat, red, grn, blu);
+		else {
+		  rgb = 0;
+		  G_warning(_("Error in color definition column GRASSRGB, area %d with cat %d: colorstring %s"),
+			    area, cat, colorstring);
+	      else {
+		G_warning(_("Error in color definition column GRASSRGB, area %d with cat %d"),
+			  area, cat);
+		rgb = 0;
+	  } /* end if cat */
+	  else {
+	    rgb = 0;
 	} /* end if table_colors_flag */
 	/* random colors */
 	if( cats_color_flag ) {
-	     if( cat >= 0 ){
-		/* fetch color number from category */
-		which = (cat % palette_ncolors);
-		G_debug(3,"cat:%d which color:%d r:%d g:%d b:%d",cat, which,palette[which].R,palette[which].G,palette[which].B);
-		R_RGB_color (palette[which].R,palette[which].G,palette[which].B);
+	    if( cat >= 0 ){
+	      /* fetch color number from category */
+	      which = (cat % palette_ncolors);
+	      G_debug(3,"cat:%d which color:%d r:%d g:%d b:%d",cat, which,palette[which].R,palette[which].G,palette[which].B);
+	      rgb = 1;
+	      red = palette[which].R;
+	      grn = palette[which].G;
+	      blu = palette[which].B;
+	    else {
+	      rgb = 0;
-	if ( fcolor > -1 && !table_colors_flag && !cats_color_flag) {
-                R_color(fcolor) ;
+	if ( fcolor > -1 ) {
+	  if (!table_colors_flag && !cats_color_flag) {
+	    R_color(fcolor) ;
+	  else {
+	    if (rgb) {
+	      R_RGB_color ((unsigned char) red, (unsigned char) grn, (unsigned char) blu);
+	    else {
+	      R_color (fcolor);
+	  G_plot_polygon ( Points->x, Points->y, Points->n_points);
 	/* boundary */
 	if ( bcolor > -1 ) {
 	    int i, j;
 	    Vect_get_area_points ( Map, area, Points );
-	    R_color(bcolor) ;
+	    if (rgb) {
+	    else {
+	      R_color (bcolor);
 	    for ( i = 0; i < Points->n_points - 1; i++) {
 		G_plot_line (Points->x[i], Points->y[i], Points->x[i+1], Points->y[i+1]);
@@ -215,14 +246,11 @@
     } /* end for */
-    if( table_colors_flag ) {
-       db_close_database(driver);
-       db_shutdown_driver(driver);
     Vect_destroy_line_struct (Points);
+    Vect_destroy_line_struct (IPoints);
     Vect_destroy_cats_struct (Cats);
+    Vect_destroy_list (isles);
     return 0;
diff -ru display/d.vect.cvs/description.html display/d.vect/description.html
--- display/d.vect.cvs/description.html	2005-04-05 09:56:15.000000000 +0200
+++ display/d.vect/description.html	2005-10-20 18:34:13.000000000 +0200
@@ -10,12 +10,11 @@
 specify vector type, colors, data fields, SQL queries, label size and
 justification, etc.
 <P>
-Vector area fill-colors may be specified in an attribute table column
-named 'GRASSRGB' (which is a <tt>varchar</tt> column containing <tt>RRR:GGG:BBB</tt> values).
-The <em>-a</em> flag is then used to fill areas based upon the color value
-associated with each category number.
+Colors may be specified in an attribute table column
+named 'GRASSRGB' (which is a <tt>varchar</tt> column containing <tt>RRR:GGG:BBB</tt> values),
+see the flag <em>-a</em>.
 <P>
-A table for a vector area map might look like this:
+A table for a vector map might look like this:
 <PRE>
   echo "select * from testisola" | db.select
@@ -39,7 +38,7 @@
 </PRE>
 <P>
 A much simpler method of color coding is by using the <em>-c</em> flag which
-fills areas of like category number with a random color.
+displays vector elements of like category number with a random color.
 <P>
 This module can use FreeType/TrueType fonts if they have already been selected with
 <em>d.font.freetype</em>.
diff -ru display/d.vect.cvs/local_proto.h display/d.vect/local_proto.h
--- display/d.vect.cvs/local_proto.h	2004-02-25 18:15:01.000000000 +0100
+++ display/d.vect/local_proto.h	2005-10-20 18:34:13.000000000 +0200
@@ -1,6 +1,6 @@
 FILE *open_vect(char *, char *);
 int close_vect(FILE *);
-int plot1(struct Map_info *, int, int, struct cat_list *, int, int, int, SYMBOL *, int, int);
+int plot1(struct Map_info *, int, int, struct cat_list *, int, int, int, SYMBOL *, int, int, int, int);
 int label(struct Map_info *, int, int, struct cat_list *, LATTR *, int);
 int topo(struct Map_info *, int, int, LATTR *);
 int dir(struct Map_info *, int, struct cat_list *, int);
diff -ru display/d.vect.cvs/main.c display/d.vect/main.c
--- display/d.vect.cvs/main.c	2005-08-16 21:32:39.000000000 +0200
+++ display/d.vect/main.c	2005-10-20 18:34:13.000000000 +0200
@@ -242,12 +242,12 @@
 	table_acolors_flag = G_define_flag ();
 	table_acolors_flag->key		= 'a';
 	table_acolors_flag->description	=
-	    _("Get area fill colors from map table column 'GRASSRGB' (RRR:GGG:BBB)");
+	    _("Get colors from map table column 'GRASSRGB' (RRR:GGG:BBB)");
 	cats_acolors_flag = G_define_flag ();
 	cats_acolors_flag->key		= 'c';
 	cats_acolors_flag->description	=
-	    _("Fill areas with random colors according to category number");
+	    _("Random colors according to category number");
 	id_flag = G_define_flag ();
 	id_flag->key		= 'i';
@@ -518,7 +518,7 @@
 		if ( id_flag->answer && level < 2 ) {
 		    G_warning(_("Cannot display lines by id, topology not available"));
 		} else {
-		    stat = plot1 ( &Map, type, area, Clist, color, fcolor, chcat, Symb, size, (int) id_flag->answer );
+		    stat = plot1 ( &Map, type, area, Clist, color, fcolor, chcat, Symb, size, (int) id_flag->answer, table_acolors_flag->answer, cats_acolors_flag->answer);
Binární soubory display/d.vect.cvs/OBJ.i686-pc-linux-gnu/area.o a display/d.vect/OBJ.i686-pc-linux-gnu/area.o jsou rùzné
Binární soubory display/d.vect.cvs/OBJ.i686-pc-linux-gnu/attr.o a display/d.vect/OBJ.i686-pc-linux-gnu/attr.o jsou rùzné
Binární soubory display/d.vect.cvs/OBJ.i686-pc-linux-gnu/dir.o a display/d.vect/OBJ.i686-pc-linux-gnu/dir.o jsou rùzné
Binární soubory display/d.vect.cvs/OBJ.i686-pc-linux-gnu/label.o a display/d.vect/OBJ.i686-pc-linux-gnu/label.o jsou rùzné
Binární soubory display/d.vect.cvs/OBJ.i686-pc-linux-gnu/main.o a display/d.vect/OBJ.i686-pc-linux-gnu/main.o jsou rùzné
Binární soubory display/d.vect.cvs/OBJ.i686-pc-linux-gnu/plot1.o a display/d.vect/OBJ.i686-pc-linux-gnu/plot1.o jsou rùzné
Binární soubory display/d.vect.cvs/OBJ.i686-pc-linux-gnu/topo.o a display/d.vect/OBJ.i686-pc-linux-gnu/topo.o jsou rùzné
Binární soubory display/d.vect.cvs/OBJ.i686-pc-linux-gnu/zcoor.o a display/d.vect/OBJ.i686-pc-linux-gnu/zcoor.o jsou rùzné
diff -ru display/d.vect.cvs/plot.h display/d.vect/plot.h
--- display/d.vect.cvs/plot.h	2003-03-21 19:01:19.000000000 +0100
+++ display/d.vect/plot.h	2005-10-20 18:34:13.000000000 +0200
@@ -1,3 +1,28 @@
+/* TODO: should use 24bit instead of 16 colors, maybe implement
+   predefined color tables? */
+struct rgb_color {
+        unsigned char R, G, B;
+static const int palette_ncolors = 16;
+static struct rgb_color palette[16] =  {
+	{198, 198, 198}, /*  1: light gray */
+	{127, 127, 127}, /*  2: medium/dark gray */
+	{255,   0,   0}, /*  3: bright red */
+	{139,   0,   0}, /*  4: dark red */
+	{  0, 255,   0}, /*  5: bright green */
+	{  0, 139,   0}, /*  6: dark green */
+	{  0,   0, 255}, /*  7: bright blue */
+	{  0,   0, 139}, /*  8: dark blue   */
+	{255, 255,   0}, /*  9: yellow */
+	{139, 126,  10}, /* 10: olivey brown */
+	{255, 165,   0}, /* 11: orange */
+	{255, 192, 203}, /* 12: pink   */
+	{255,   0, 255}, /* 13: magenta */
+	{139,   0, 139}, /* 14: dark magenta */
+	{  0, 255, 255}, /* 15: cyan */
+	{  0, 139, 139}  /* 16: dark cyan */
 typedef struct {
     int    field;
diff -ru display/d.vect.cvs/plot1.c display/d.vect/plot1.c
--- display/d.vect.cvs/plot1.c	2005-08-09 13:26:59.000000000 +0200
+++ display/d.vect/plot1.c	2005-10-20 18:34:13.000000000 +0200
@@ -7,12 +7,14 @@
 #include "plot.h"
 #include "symbol.h"
+#include "dbmi.h"
 int plot1 (
     struct Map_info *Map, int type, int area,
-    struct cat_list *Clist, int color, int fcolor, int chcat, SYMBOL *Symb, int size, int id_flag)
+    struct cat_list *Clist, int color, int fcolor, int chcat, SYMBOL *Symb, int size, int id_flag,
+    int table_colors_flag, int cats_color_flag)
-    int i, j, k, ltype, nlines = 0, line;
+    int i, j, k, ltype, nlines = 0, line, cat = -1;
     double *x, *y, xd, yd, xd0 = 0, yd0 = 0;
     struct line_pnts *Points, *PPoints;
@@ -21,17 +23,61 @@
     SYMBCHAIN *chain;
     int x0, y0, xp, yp;
-    msize = size * ( D_d_to_u_col(2.0) - D_d_to_u_col(1.0) ); /* do it better */
+    dbDriver *driver = NULL;
+    int nrec;
+    int rgb; /* 0|1 */
+    int red, grn, blu;
+    unsigned char which;
+    msize = size * ( D_d_to_u_col(2.0) - D_d_to_u_col(1.0 ) ); /* do it better */
     Points = Vect_new_line_struct ();
     PPoints = Vect_new_line_struct ();
     Cats = Vect_new_cats_struct ();
+    if( table_colors_flag ) {
+      /* for reading RRR:GGG:BBB color strings from table */
+      if (fi == NULL) {
     Vect_rewind ( Map );
     /* Is it necessary to reset line/label color in each loop ? */
-    if ( color > -1 ) R_color(color) ;
+    if ( color > -1 && !table_colors_flag && !cats_color_flag) R_color(color) ;
     if ( Vect_level ( Map ) >= 2 )
 	nlines = Vect_get_num_lines ( Map );
@@ -67,12 +113,72 @@
 		 for ( i = 0; i < Cats->n_cats; i++ ) {
 		     if ( Cats->field[i] == Clist->field && Vect_cat_in_cat_list ( Cats->cat[i], Clist) ) {
 			 found = 1;
+			 cat = Cats->cat[i];
                          break;
                  if (!found) continue;
+	  cat=Vect_get_line_cat ( Map, line, Clist->field ); /* only first category */
+	  if (cat >= 0) {
+	    G_debug (3, "display element %d, cat %d", line, cat);
+	      rgb = 0;
+	    else {
+		G_debug(3, "element %d: colorstring: %s", line, colorstring);
+		  rgb = 1;
+		  G_debug(3, "element:%d  cat %d r:%d g:%d b:%d", line, cat, red, grn, blu);
+		else {
+		  rgb = 0;
+		  G_warning(_("Error in color definition column GRASSRGB, element %d with cat %d: colorstring %s"), line, cat, colorstring);
+	      else {
+		rgb = 0;
+		G_warning(_("Error in color definition column GRASSRGB, element %d with cat %d"), line, cat);
+	  else {
+	    rgb = 0;
+	} /* end if table_colors_flag */
+	/* random colors */
+	if( cats_color_flag ) {
+	  if( cat >= 0 ){
+	    G_debug(3,"cat:%d which color:%d r:%d g:%d b:%d", cat, which,
+		    palette[which].R, palette[which].G, palette[which].B);
+	    rgb = 1;
+	  else {
+	    rgb = 0;
 	x = Points->x;
 	y = Points->y;
@@ -91,10 +197,20 @@
 			if ( (part->fcolor.color == S_COL_DEFAULT && fcolor > -1) ||
 			      part->fcolor.color == S_COL_DEFINED )
-			    if ( part->fcolor.color == S_COL_DEFAULT )
+			      if ( part->fcolor.color == S_COL_DEFAULT )
 				R_color(fcolor);
-			    else
+			      else
 				R_RGB_color ( part->fcolor.r, part->fcolor.g, part->fcolor.b );
+			  else {
+			    if (rgb) {
+			    else {
+			      R_color (fcolor);
 			    Vect_reset_line ( PPoints );
@@ -124,7 +240,7 @@
 			    } else {
 			        R_RGB_color ( part->color.r, part->color.g, part->color.b );
 			    for ( j = 0; j < part->count; j++ ) {
 				chain = part->chain[j];
 				for ( k = 0; k < chain->scount; k++ ) {
@@ -141,8 +257,25 @@
                         break;
                     case S_STRING:
 			if ( part->color.color == S_COL_NONE ) break;
-			else if ( part->color.color == S_COL_DEFAULT ) R_color(color) ;
-			else R_RGB_color ( part->color.r, part->color.g, part->color.b );
+			else {
+			    if ( part->color.color == S_COL_DEFAULT ) R_color(color) ;
+			    else R_RGB_color ( part->color.r, part->color.g, part->color.b );
+			  else {
+			    if (ltype == GV_CENTROID) {
+			      R_color (color);
+			    else {
+			      if (rgb) {
+			      else {
+				R_color (color);
 			chain = part->chain[0];
@@ -156,8 +289,18 @@
                         break;
-            if (color > -1) R_color(color) ; /* Reset color */
-        } else if (color > -1 ) {
+	} else if (color > -1 ) {
+	    R_color (color);
+	  else {
+	    if (rgb) {
+	    else {
+	      R_color (color);
 	    if ( Points->n_points == 1 ) { /* line with one coor */
 	        G_plot_line(x[0], y[0], x[0], y[0]);
 	    } else {
--- d.vect.18/area.c	2005-10-24 00:03:10.000000000 +0200
+++ d.vect/area.c	2005-10-24 00:18:39.000000000 +0200
@@ -20,8 +20,9 @@
     int red, grn, blu;
@@ -72,14 +73,26 @@
+	if (isle > 0) {
 	int i;
 	BOUND_BOX box;
 	/* Check box */
@@ -136,7 +149,7 @@
@@ -196,20 +209,15 @@
-	  if (Vect_get_isle_area (Map, area)) { /* isle ? */
-	    R_RGB_color (255, 255, 255);
+	    R_color(fcolor) ;
 	  else {
-	    if (!table_colors_flag && !cats_color_flag) {
-	      R_color(fcolor) ;
+	    if (rgb) {
 	    else {
-	      if (rgb) {
-	      else {
 	      R_color (fcolor);
@@ -239,8 +247,10 @@
     } /* end for */
     return 0;
