[GRASS5] v.external, OGR/OCI and v.in.ogr
Radim Blazek radim.blazek at gmail.com
Mon Dec 12 13:25:17 EST 2005
On 12/12/05, Stephan Holl <holl at gdf-hannover.de> wrote:
> Hello Radim,
> On Mon, 12 Dec 2005 13:07:57 +0100 Radim Blazek
> <radim.blazek at gmail.com> wrote:
> > > When I log into Oracle, both datasets habe the same FID-colum
> > > (OGR_FID), but the one GRASS created is always 1 and does not
> > > increment.
> > > I am stuck.
> > > Where should I start searching for the errors?
> > Probably missing OGRFeature::SetFID in v.out.ogr.
> Are you going to look into this?
Not now.
> I am no programmer and do not know
> where to insert this.
Not difficult, use GRASS internal line and area+Vect_get_num_lines() numbers.
Radim
