[GRASS5] [bug #2829] (grass) v.to.db: remove an option and am suddenly out of range
Maciek Sieczka werchowyna at epf.pl
Tue Dec 13 05:39:21 EST 2005
On wto, 2005-12-13 at 11:05 +0100, Radim Blazek wrote:
> On 12/13/05, Maciek Sieczka <werchowyna at epf.pl> wrote:
> > I wish this could be unified for all Grass modules:
> > 1. If the user doesn't specify the column name a column with a
> > reasonable default name is created and populated.
> > 2. The possibility to override column name by user is preserved.
> That would be bad in my opinion, because if user forgets to give
> a column name the module can modify his data. It sounds too Windows like,
> I mean it automaticaly does something what you dont want.
> I suggest to add a new flag (e.g. -c) to create a new column
> (specified by user) if it does not exist.
You are right. That would be the best solution.
Maciek
W polskim Internecie s± setki milionów stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.epf.pl/
