[GRASS5] [bug #3895] (grass) v.out.ogr in Oracle using OGR/OCI
Request Tracker
grass-bugs at intevation.de
Tue Dec 13 09:46:38 EST 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3895
Subject: v.out.ogr in Oracle using OGR/OCI
Problem:
v.out.ogr does not increment the OGR Feature-Id when exporting into Oracle
Spatial via v.out.ogr. This results in errors when trying to reimport (e.g.
using v.external) because of the OGRFeature() is always 1.
Radims suggested solution:
Probably missing OGRFeature::SetFID in v.out.ogr.
> I am no programmer and do not know
> where to insert this.
Not difficult, use GRASS internal line and area+Vect_get_num_lines() numbers.
Thanks for "not forgetting" about this.
Best
Stephan
The full Diskussion-thread on grass5 can be found here:
http://grass.itc.it/pipermail/grass5/2005-December/020380.html
-------------------------------------------- Managed by Request Tracker
