[GRASS5] Why is r.to.rast3 missing?
Michael Barton
michael.barton at asu.edu
Thu Dec 15 11:15:27 EST 2005
Can r3.cross.rast get into the CVS too? This is a great tool.
I'm name neutral about this as long as I get it right and put it in the menu
correctly.
However, if I wanted to get philosophical, I'd say that you should name the
module with respect to the file type you start with for type conversion
within grass. Things starting with raster and converting to something else
should be r.to.xxx. Things starting with rast3 should be r3.to.xxx.
Currently we have r.to.vect and v.to rast for example.
Michael
______________________________
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Sören Gebbert <soerengebbert at gmx.de>
> Date: Thu, 15 Dec 2005 16:58:51 +0100 (MET)
> To: Helena Mitasova <hmitaso at unity.ncsu.edu>
> Cc: <michael.barton at asu.edu>, <grass5 at grass.itc.it>
> Subject: Re: [GRASS5] Why is r.to.rast3 missing?
> Maybe we should rename r3.in.rast to r.to.rast3 and move it into the
> grass6/raster directoy,
> to prevent name confusions?
> btw.:
> there is also a module called r3.cross.rast, which produces cross section
> raster maps from 3d maps,
> at my homepage. Should i rename it to r.cross.rast3?
> my homepage:
> http://www-pool.math.tu-berlin.de/~soeren/grass/modules/
> Soeren
>> Michael Barton wrote:
>>> Any reason why r.to.rast3 is missing from the normal GRASS distribution?
>> it is there - it is called r3.in.rast. I always forget the name too and
>> look for it.
>> Helena
> Lust, ein paar Euro nebenbei zu verdienen? Ohne Kosten, ohne Risiko!
> Satte Provisionen f�r GMX Partner: http://www.gmx.net/de/go/partner
