[GRASS5] Column-names of FeatureID in OGR
Stephan Holl
holl at gdf-hannover.de
Fri Dec 16 04:18:15 EST 2005
Hello Radim,
On Wed, 14 Dec 2005 15:09:54 +0100 Radim Blazek
<radim.blazek at gmail.com> wrote:
> On 12/14/05, Stephan Holl <holl at gdf-hannover.de> wrote:
> > Dear list,
> > I can remember a former discussion about the column-nameings for the
> > different OGR-drivers. Currently GRASS cycles through 3 different
> > FID-namings (FID, ogc_fid, ogr_fid) and trys to link the attributes
> > (see $GRASSBASE/lib/vector/Vlib/fields.c:395)
> > I need to connect to a oracle-database with v.external where the
> > Feature-IDs are named different than the 3 tried columns.
> > Consequently v.extrenal fails.
> > Is there a chance that a user can specify the FID-column-name on
> > the command-line? This would be very handy, otherwise I need to add
> > another column to the oracle-tables which is named ether FID,
> > ogc_fid or ogr_fid.
> > What would be the best solution for this?
> > What do you think?
> The best solution is a new method in OGR which gives FID column name.
> Frank already promissed to add it . Please fill OGR bug and try to
> increase priority.
According to the former discussion with Frank W. I have added a
bug-report on the OGR-bugzilla[1].
Best regards
Stephan
[1] http://bugzilla.remotesensing.org/show_bug.cgi?id=1019
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office - Mengendamm 16d - D-30177 Hannover
Internet: www.gdf-hannover.de - Email: holl at gdf-hannover.de
Phone : ++49-(0)511.39088507 - Fax: ++49-(0)511.39088508
