[GRASS5] Fwd: Indic support in GRASS GIS with Indix2
Sajith VK sajithvk at gmail.com
Tue Dec 20 04:08:06 EST 2005
Hello,
I too dont know whether GUI team will keep the existing monitor in the "next
generation GUI". I think the road map for next GUI is not yet ready. So for the
time being, your work seems to be highly beneficial.
Can some one working on the GUI give their comments?
On 12/19/05, Swapnil Hajare <dreamil at gmail.com> wrote:
> hi,
>  greetings.
>   not sure if the new GTK gui will solve our problem. Does the new GUI means
> GRASS monitors will use pango for rendering? I guess they will use the same
> monitor. And by the time they come up with new GUI, should we wait for them
> to finish and then start our localised GIS work ? My feeling is this should
> be seen as a patch for indic support (similar to d.text.freetype used for
> CJK). correct me if I am wrong.
>   I am also not sure  how many indic scripts are supported well by Pango/QT
> and what is the quality of rendering for all these scripts. If this solution
> can provide a better rendering solution, it has every right to be accepted
> as a good alternative to Pango/Qt.
> bye
Change the rules, or the rules will change you
     ---------Kumaranasan
