[GRASS5] pg.dll was not found
Hamish
hamish_nospam at yahoo.com
Tue Dec 20 17:21:36 EST 2005
> I have a problem when I try to create location from epsg. I get a
> message as "This application has failed to start because pg.dll was
> not found. Re-installing the application may fiz the problem"
> I use windows XP and installed the software as told in page
> http://geni.ath.cx/grass.html
You will see in the screenshot of the cygwin installer (just before step
#6) that postgresql is selected for install. Make sure it is.
I guess either a dependancy in the grass package needs to be fixed or
the instructions have to state that more explicitly.
Hamish
