[GRASS5] GRASS 6.0.1 compilation on Suse 9.1
Muzaffer Ayvaz muzafferayvaz at yahoo.com
Tue Dec 27 09:09:54 EST 2005
Hi all;
I have downloaded grass-6.0.1 sources from the
grass.itc.it download site, and try to compile on Suse
9.1 with;
export CFLAGS='-g -Wall'
./configure \
  --with-cxx \
  --with-gdal=/usr/local/bin/gdal-config \
  --with-postgres-includes=/usr/include/pgsql
--with-postgres-libs=/usr/lib \
  --without-mysql \
  --without-odbc \
  --with-motif \
  --with-motif-includes=/usr/X11R6/include/Xm \
  --with-glw \
  --with-nls \
  --with-fftw --with-fftw-libs=/usr/local/lib \
  --with-freetype
  --enable-largefile \
  --with-opendwg
--with-opendwg-includes=/ssi0/ssi/neteler/software/openDWG
--with-opendwg-libs=/ssi0/ssi/neteler/software/openDWG
This is the conf61_linux.sh file of Markus Neteler.
But an error occured:
checking whether to use GDAL... yes
yes
checking for gdal-config... /usr/local/bin/gdal-config
./configure: line 1: /usr/local/bin/gdal-config: No
such file or directory
./configure: line 7118: test: =: unary operator
expected
checking for GDALOpen... no
configure: error: *** Unable to locate GDAL library.
Before I had install grass 6.0.1 from the rpm packages
and works fine.I had also download both gdal-1.3.1 and
gadl-grass-1.3.1.1 from the rpm packes. But there is
not a file named "gdal-config" in my computer
anywhere.
How can I solve this problem?
Thank you for all...
Muzaffer...
__________________________________
Yahoo! for Good - Make a difference this year.
http://brand.yahoo.com/cybergivingweek2005/
