[GRASS5] GRASS 6.0.1 compilation on Suse 9.1
Muzaffer Ayvaz
muzafferayvaz at yahoo.com
Wed Dec 28 09:54:30 EST 2005
I have solved the problem by installing gdal-devel package.
Thank you very much Maciek.
Best Regards
Muzaffer....
Maciek Sieczka <werchowyna at epf.pl> wrote:
On wto, 2005-12-27 at 06:09 -0800, Muzaffer Ayvaz wrote:
> Hi all;
> I have downloaded grass-6.0.1 sources from the
> grass.itc.it download site, and try to compile on Suse
> 9.1 with;
> export CFLAGS='-g -Wall'
> ./configure \
> --with-cxx \
> --with-gdal=/usr/local/bin/gdal-config \
> --with-postgres-includes=/usr/include/pgsql
> --with-postgres-libs=/usr/lib \
> --without-mysql \
> --without-odbc \
> --with-motif \
> --with-motif-includes=/usr/X11R6/include/Xm \
> --with-glw \
> --with-nls \
> --with-fftw --with-fftw-libs=/usr/local/lib \
> --with-freetype
> --with-freetype-includes=/usr/include/freetype2 \
> --enable-largefile \
> --with-opendwg
> --with-opendwg-includes=/ssi0/ssi/neteler/software/openDWG
> --with-opendwg-libs=/ssi0/ssi/neteler/software/openDWG
> This is the conf61_linux.sh file of Markus Neteler.
> But an error occured:
You have to customize the ./configure syntax: set --with... only for
pieces you need, put _your_ real paths to where your software is
installed.
> checking whether to use GDAL... yes
> yes
> checking for gdal-config... /usr/local/bin/gdal-config
> ./configure: line 1: /usr/local/bin/gdal-config: No
> such file or directory
> ./configure: line 7118: test: =: unary operator
> expected
> checking for GDALOpen... no
> configure: error: *** Unable to locate GDAL library.
> Before I had install grass 6.0.1 from the rpm packages
> and works fine.I had also download both gdal-1.3.1 and
> gadl-grass-1.3.1.1 from the rpm packes. But there is
> not a file named "gdal-config" in my computer
> anywhere.
You propably need a developement package for GDAL which is called like
libgdal-dev or similar (depending on a given linux distro). The same for
all the other software which Grass depends on - you need development
packages if you build from source.
> How can I solve this problem?
> Thank you for all...
> Muzaffer...
P.S.
Better ask on grasslist at baylor.edu which is for user support. This list
is for development issues mainly.
Good Luck
Maciek
W polskim Internecie s± setki milionów stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
grass5 mailing list
grass5 at grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Yahoo! for Good - Make a difference this year.
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20051228/dace3ee3/attachment.html
