[GRASS5] [bug #3918] (grass) configure syntax error
Markus Neteler
neteler at itc.it
Fri Dec 30 03:59:31 EST 2005
On Fri, Dec 30, 2005 at 12:29:12AM +0200, Wolf Bergenheim wrote:
> Hi,
> Try executing autoconf in the grass6 root directory. and then try
> configure again.
this should not be necessary as GRASS should come with a valid
configure file. In any case, autoconf-2.13 should be used.
I just checked it on the server:
wc -l grass-6.1.cvs_src_snapshot_2005_12_24/configure
13804 grass-6.1.cvs_src_snapshot_2005_12_24/configure
Line 12859 contains
eval "ac_cv_header_$ac_safe=yes"
I have no idea what could be wrong.
Markus
> --W
> <:3 )---- Wolf Bergenheim ----( 8:>
> On 29/12/05 20:48, Request Tracker wrote:
> > this bug's URL: http://intevation.de/rt/webrt?serial_num=3918
> > Subject: configure syntax error
> > Platform: other
> > grass obtained from: CVS
> > grass binary for platform: Compiled from Sources
> > When I try ./configure script I got this error:
> > checking system version (for dynamic loading)... ./configure: line 12859: syntax error: unexpected end of file
> > I use CVS source grass-6.0.cvs_src_snapshot_2005_12_24 and bash as /bin/sh version "GNU bash, version 3.1.1(1)-release (x86_64-pc-linux-gnu)"
> > Pavel Mlčoch <pavkamlc at centrum.cz>
> > -------------------------------------------- Managed by Request Tracker
> > grass5 mailing list
> > grass5 at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass5
> grass5 mailing list
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
