[GRASS5] Re: [GRASSLIST:9669] compilation (again)
Paolo Cavallini
cavallini at faunalia.it
Fri Dec 30 05:31:41 EST 2005
Hi all.
At 10:03, venerdì 30 dicembre 2005, Markus Neteler has probably written:
> Ciao Paolo,
> [maybe better posted to the devel list]
> On Thu, Dec 29, 2005 at 05:47:25PM +0100, Paolo Cavallini wrote:
> > Hi all.
> > Still problems compiling grass from 6.1cvs:
> ... "still"? I thought it worked for you recently...
It worked after several trials, but only removing a couple of modules
(r.sim.water r.sim.sediment).
> > checking if 64bit Sparc VIS support is requested... no
> > checking system version (for dynamic loading)... ./configure: line 13675:
> > unexpected EOF while looking for matching `''
> > ./configure: line 13805: syntax error: unexpected end of file
> > make: *** [config.status] Error 2
> > Any hint?
Tried again:
> What does
> cvs up configure
> say (conflict)?
nothing.
> Best
> Markus
Paolo Cavallini
email+jabber: cavallini at faunalia.it
www.faunalia.it
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
