[GRASS5] An error in v.surf.idw main program --- may be a bug.
Fri Dec 30 17:25:04 EST 2005
Muzaffer Ayvaz wrote:
>   While i am compiling the grass source codes gcc shows a warning. for the line
>     /* interpolate */
>   sum1 = 0.0;
>   sum2 = 0.0;
>   for (n = 0; n < nsearch; n++)
>   if(dist = list[n].dist)
>   The code is like that in both 6.0.1 version and 6.0.2RC1.
>   is it an error or anythig else.
No, it's correct, but could be written better as:
	dist = list[n].dist;
	if (dist)
or:
	if(dist = list[n].dist, dist)
> i think it must be;
>     if ( dist == list[n].dist)
No, the assignment must be performed.
