[GRASS5] Re: [Fwd: whinging about GRASS again]
Radim Blazek
blazek at itc.it
Tue Feb 1 04:31:30 EST 2005
Russell Nelson wrote:
> No, that's not it. It's not that they didn't like my solution. It's
> that they didn't like my problem. No solution can satisfy a
> non-problem.
Not at all! The problem is evident. We just don't like the solution. You
say "The trouble with GRASS is that, at its core ..." and you want to
change the core, which can break everything.
Cefn Hoile wrote:
| The question is, could a straightforward modification of the UI tool be
| made to solve this problem, without threatening the generality of the
| toolset.
Exactly.
> I think the solution is just as you suggested: to create a front-end
> which is helpful. Doesn't require any changes to GRASS.
This sounds much more reasonable than changing the core.
> GRASS developers acknowledge that GRASS is hard to use
> on one hand, but they also say that fixing that problem is not a
> priority for them.
It WAS not the priority for me until last year. There were serious
problems in GRASS vectors in 5.x. Do you know, that you can lose vector
attributes immediately after import to 5.x? Because we also use GRASS
for work, we needed something more reliable first. Now it is time to
work on UI.
About the subject itself:
To start with GRASS without an existing location is realy painful.
I think that at least 2 improvements can be done:
1) We can create a list of predefined locations (name + description +
projection + datum + region) which can be selected in startup screen
instead of that terrible "Create location from EPSG"
2) The possibility to create a new GRASS location can be added to QGIS.
The advantage of QGIS is, that a user can open and view imported files
without GRASS. In GRASS it can take very long time until you see
something and that is probably the most frustrating moment. Once the map
is opened in QGIS, we know at least the region but possibly also the
projections, because it can be defined in nice GUI in QGIS:
http://mpa.itc.it/radim/qgis/projection.png
Radim
