[GRASS5] Re: Large image fuzziness?
David Piasecki
piasecda at nv.doe.gov
Tue Feb 1 14:37:41 EST 2005
You may disregard my previous question regarding large images being
fuzzy. It turns out, thankfully, that the image churned out by GRASS is
perfectly fine. For some reason, it is not being read correctly in
Apple's Preview application, and larger images will be displayed at a
lower resolution. I guess this is why they call it "Preview". When I
finally gave up and imported the image directly into my application
(also using Apple Cocoa objects, which is why I didn't try in the first
place), it was crystal clear.
Thanks,
David
