[GRASS5] r.mapcalc question
David Piasecki
piasecda at nv.doe.gov
Wed Feb 2 18:23:04 EST 2005
Paul,
You were right. Seems the best plan of action is to do the following:
r.mapcalc calc.red=image0.red // creates the image with the correct
region information
r.mapcalc
'calc.red=if(isnull(calc.red),if(not(isnull(image1.red)),image1.red,if(n
ot(isnull(image2.red)),image2.red)),calc.red)' // and so on...
imageN.red
// do the same for green and blue
r.composite r_map=calc.red g_map=calc.green b_map=calc.blue output=cmap
// form an rgb composite image
And now I can do whatever I want with it :)
Perhaps this isn't quite the fastest method, but it works. If anyone
knows of a more efficient way of doing the same thing, I'd be
interested in taking suggestions.
Thanks,
David
On Feb 2, 2005, at 12:37 PM, Paul Kelly wrote:
> On Wed, 2 Feb 2005, David Piasecki wrote:
>> r.mapcalc
>> 'calc.red=if(isnull(image0.red),image1.red,if(isnull(image1.red),image
>> 0. red))'
>> That's great; however, I have 42 images. So I tried some logic...
>> r.mapcalc 'calc.red=( image0.red || image1.red )'
>> r.mapcalc 'calc.red=( image0.red + image1.red )'
>> I think these aren't working because GRASS has a problem evaluating
>> these expressions since image0.red is null wherever image1.red is not
>> null. However, no error messages are given. Is there an easier way to
>> do this than the first command given above?
> Assuming none of your non-NULL cells have a value of 0, perhaps
> convert all the nulls to 0 using r.null? What you have written
> probably would have worked in GRASS 4 before NULLs were introduced. In
> GRASS 5, if any of the input maps for a cell in r.mapcalc are null
> then the output cell is null.
> Something like
> r.null image0.red null=0
> r.null image1.red null=0
> might do what you want. But your first way is more correct IMHO and
> probably the way it should be done.
> Paul
