[GRASS5] r.mapcalc question
    David Piasecki
    piasecda at nv.doe.gov
    Thu Feb  3 11:42:23 EST 2005
When I tried running r.patch, it took a really long time. Since I'd
never used r.mapcalc before, I thought it might be faster. The line I
wrote in r.mapcalc seems to be checking if a pixel is null, then
finding the image with that pixel and drawing it. I assumed r.patch was
writing all pixels from every image every time. If it's not any faster,
then yes, I might as well use r.patch.
Although my r.mapcalc line worked the first time, I have yet to be able
to repeat it. For some reason, the region information changes to the
(x,y) projection, and then I assume it's attempting to draw someplace
else. So I may end up returning to r.patch anyway.
David
On Feb 2, 2005, at 5:26 PM, Hamish wrote:
>> Perhaps this isn't quite the fastest method, but it works. If anyone
>> knows of a more efficient way of doing the same thing, I'd be
>> interested in taking suggestions.
> so what is wrong with r.patch exactly? If it does what you want it's a
> bit less prone to user error than r.mapcalc and in theory it should
> cycle through the raster cells at about the same speed?
> r.patch can take a couple hundred input maps at once (in preferential
> order).
> Hamish
