[GRASS5] r.mapcalc question
David Piasecki
piasecda at nv.doe.gov
Fri Feb 4 11:19:59 EST 2005
Yeah, I think r.patch may, in fact, run faster, but it sounds like you
already knew this. Anyway, I've got another small question. Right now
I'm determining what the region encompassing a set of jpg images is by
doing a d.rast -o image# for all images, followed by a d.extend. That
works, but it's kind of annoying to have to draw to a graphics monitor
when I don't need to. Is there a way to set the region based on a
collection of raster data without having to draw?
Thanks,
David
On Feb 2, 2005, at 5:26 PM, Hamish wrote:
>> Perhaps this isn't quite the fastest method, but it works. If anyone
>> knows of a more efficient way of doing the same thing, I'd be
>> interested in taking suggestions.
> so what is wrong with r.patch exactly? If it does what you want it's a
> bit less prone to user error than r.mapcalc and in theory it should
> cycle through the raster cells at about the same speed?
> r.patch can take a couple hundred input maps at once (in preferential
> order).
> Hamish
