[GRASS5] [bug #2937] (grass) v.in.ogr, GUI, fails during "Building areas:"
Maciek Sieczka werchowyna at pf.pl
Sun Feb 6 19:07:03 EST 2005
Hi
I had problem with the v.in.ogr GUI again with another file. This time
nothing was printed to terminal and the whole GIS Manager and all windows
freezed and I had to kill the GUI. The file failed to import. Here's a
screendump attached of the v.in.ogr and the error pop-up.
In the next d.m session trying to import this file from GUI once more
crashed again, but this time the GUI survived and the error, similar to the
bug report below, was printed to the terminal. Again, importing this file in
command line works ok.
Maciek
----- Original Message -----
From: "Request Tracker" <grass-bugs at intevation.de>
To: <grass5 at grass.itc.it>
Sent: Monday, January 24, 2005 11:54 PM
Subject: [GRASS5] [bug #2937] (grass) v.in.ogr, GUI, fails during "Building
areas:"
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2937
> Subject: v.in.ogr, GUI, fails during "Building areas:"
> Platform: GNU/Linux/i386
> grass obtained from: Mirror of Trento site
> grass binary for platform: Compiled from Sources
> GRASS Version: grass-6.0.cvs_src_snapshot__2005_01_15
> My system: Mdk10.1, gcc 3.3.4.
> v.in.ogr works fine directly from the terminal, but fails during "Building
> areas:" when invoked from GUI. Then it prints to the terminal as follows:
> GRASS 6.0.cvs:~ > too many nested evaluations (infinite loop?)
>    (procedure "GlobalVar::exists" line 1)
>    invoked from within
> "GlobalVar::exists $_widget($path,var)"
>    (procedure "ProgressBar::_modify" line 4)
>    invoked from within
> "ProgressBar::_modify .dialog0.progress"
>    ("eval" body line 1)
>    invoked from within
> "eval ProgressBar::$cmd .dialog0.progress $args"
>    (procedure ".dialog0.progress" line 1)
>    invoked from within
> "$opt($dlg,progress) _modify"
>    (procedure "progress" line 7)
>    invoked from within
> "progress $dlg $val"
>    invoked from within
> "if [eof $fh] {
>                close $fh
>        } else {
>                set str [gets $fh]
>                append str "\n"
>                if { [fblocked $fh] } { set str [read $fh] }
>                while {[set idx [string f..."
>    (procedure "prnout" line 5)
>    invoked from within
> "prnout 1 file6"
> GRASS 6.0.cvs:~ >
> Here goes the message displayed in the GUI widnow during import, prior to
> failure:
> v.in.ogr dsn=/home/maciek/polska_shp/granica92/granica.shp output=granice
> min_area=0.0001 snap=-1
> A datum name etrs89 (European_Terrestrial_Reference_System_1989) was
> specified without transformation parameters.
> Note that the GRASS default for etrs89 is towgs84=0.000,0.000,0.000.
> Projection of input dataset and current location appear to match.
> Proceeding with import...
> Layer: granica
> Building topology ...
> Registering lines:
> 43 primitives registered
> Building areas:
> 41 areas built
> 41 isles built
> Attaching islands:
> Attaching centroids:
> Topology was built.
> Number of nodes     :   42
> Number of primitives:   43
> Number of points    :   0
> Number of lines     :   0
> Number of boundaries:   43
> Number of centroids :   0
> Number of areas     :   41
> Number of isles     :   41
> Number of incorrect boundaries   :   2
> Number of areas without centroid :   41
> Cleaning polygons, result is not guaranteed!
> Topology was built.
> Number of lines     :   0
> Number of areas     :   -
> Number of isles     :   -
> Break polygons:
> Registering points ... 3154
> All points (vertices):  5033
> Registered points (unique coordinates):  3154
> Points marked for break:    81
> Breaks:     0
> Breaks:    30
> Breaks:    47
> Breaks:    74
> Breaks:   108
> Breaks:   143
> Remove duplicates:
> Duplicates:     0
> Duplicates:     1
> Duplicates:     2
> Duplicates:     3
> Duplicates:     4
> Duplicates:     5
> Duplicates:     6
> Duplicates:     7
> Duplicates:     8
> Duplicates:     9
> Duplicates:    10
> Duplicates:    11
> Duplicates:    12
> Duplicates:    13
> Duplicates:    14
> Duplicates:    15
> Duplicates:    16
> Duplicates:    17
> Duplicates:    18
> Duplicates:    19
> Duplicates:    20
> Duplicates:    21
> Duplicates:    22
> Duplicates:    23
> Duplicates:    24
> Duplicates:    25
> Duplicates:    26
> Duplicates:    27
> Duplicates:    28
> Duplicates:    29
> Duplicates:    30
> Duplicates:    31
> Duplicates:    32
> Duplicates:    33
> Duplicates:    34
> Duplicates:    35
> Duplicates:    36
> Duplicates:    37
> Duplicates:    38
> Duplicates:    39
> Duplicates:    40
> Duplicates:    41
> Duplicates:    42
> Duplicates:    43
> Duplicates:    44
> Duplicates:    45
> Duplicates:    46
> Duplicates:    47
> Duplicates:    48
> Duplicates:    49
> Duplicates:    50
> Duplicates:    51
> Duplicates:    52
> Duplicates:    53
> Duplicates:    54
> Duplicates:    55
> Duplicates:    56
> Break boundaries:
> Intersections:     0
> Intersections:     0
> Remove duplicates:
> Duplicates:     0
> Clean boundaries at nodes:
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Modifications:     0
> Change dangles to lines:
> Removed dangles:     0  removed lines:     0
> Remove bridges:
> Removed bridges:     0  removed lines:     0
> Building areas:
> 43 areas built
> 19 isles built
> Attaching islands:
> Topology was built.
> Number of nodes     :   81
> Number of primitives:   186
> Number of lines     :   0
> Number of boundaries:   186
> Number of areas     :   43
> Number of isles     :   19
> Number of areas without centroid :   43
> Layer: granica
> Registering lines:
> 148 primitives registered
> Building areas:
> Maciek
> -------------------------------------------- Managed by Request Tracker
> grass5 mailing list
> http://grass.itc.it/mailman/listinfo/grass5
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20050207/43750800/vinogr_failure.png
