[GRASS5] Re: [Pkg-grass-general] Re: QGIS and grass
Wed Feb 9 03:04:10 EST 2005
[using DebianGIS GRASS, QGIS, etc packages from Alioth]
http://pkg-grass.alioth.debian.org/cgi-bin/wiki.pl?DebianGisRepository
QGIS segfault:
 gdb is not much use without debugging symbols, but maybe it helps.
 Both starting from outside of GRASS with "export GISBASE=/usr/lib/grass"
 and from starting qgis from within GRASS.
grass6beta2, libgrass0, qgis, qgis-grass-plugin packages from today's
pkg-grass.alioth repo.
gdb /usr/bin/qgis
(gdb) run
QGIS starts, click add GRASS raster from toolbar, set location to
 Spearfish57, mapset to PERMANENT, and map to roads; click "ok" and
 segfault...]
Loaded /usr/lib/qgis/spitplugin.so
QgsGrassPlugin::addRaster
(no debugging symbols found)
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 16384 (LWP 28951)]
0x41dd839a in G_find_cell2 () from /usr/lib/grass/lib/libgrass_gis.so
(gdb) bt
#0  0x41dd839a in G_find_cell2 () from /usr/lib/grass/lib/libgrass_gis.so
#1  0x41dd8576 in G_find_file () from /usr/lib/grass/lib/libgrass_gis.so
#2  0x41dd8330 in G_find_cell () from /usr/lib/grass/lib/libgrass_gis.so
#3  0x41de90af in G_raster_map_type () from /usr/lib/grass/lib/libgrass_gis.so
#4  0x420e864f in GRASSRasterBand::GRASSRasterBand () from /usr/lib/gdal_GRASS.so
#5  0x00000000 in ?? ()
#6  0x412295d0 in ?? () from /usr/lib/libgeos.so.2
#7  0x00000000 in ?? ()
#8  0x41220138 in ?? () from /usr/lib/libgeos.so.2
#9  0x00000000 in ?? ()
#10 0x3ff00000 in ?? ()
#11 0x00000000 in ?? ()
#12 0x00000000 in ?? ()
#13 0x02987449 in ?? ()
#14 0x40737154 in ?? () from /usr/lib/libgdal.so.1
#15 0xbfffeba4 in ?? ()
#16 0x40016f88 in ?? ()
#17 0x00000002 in ?? ()
#18 0x01000001 in ?? ()
#19 0x0833d150 in ?? ()
#20 0x00000001 in ?? ()
#21 0x40a42ccc in ?? () from /usr/lib/libgdal.so.1
#22 0x01ffeba4 in ?? ()
#23 0x083369e8 in ?? ()
#24 0xbfffeb88 in ?? ()
#25 0x4087fb8f in VSIRewind () from /usr/lib/libgdal.so.1
Previous frame inner to this frame (corrupt stack?)
(gdb)
GRASS vectors work beautifully.
Hamish
