[GRASS5] r.in.gdal or GDAL bug?
Frank Warmerdam
fwarmerdam at gmail.com
Thu Feb 10 14:46:17 EST 2005
On Thu, 10 Feb 2005 12:56:43 +0100, Otto Dassau <otto.dassau at gmx.de> wrote:
> [New Thread 1086230496 (LWP 4835)]
> ERROR 1: /usr/local/lib/gdal_GRASS.so: undefined symbol: _ZN11GDALDataset10AdviseReadEiiiiii12GDALDataTypeiPiPPc
Otto,
Note that the above messages indicate that you have conflicting
versions of some source. Likely you have a gdal_GRASS.so that
was compiled against a different version of GRASS than you are
using. The AdviseRead method was recently added to GDAL.
There is no problem with compiling an older gdal_grass driver,
but the binaries have to be built against a compatible version of
GDAL to what they run under.
PS. I am subscribed to this list, but I have all [GRASS5* messages
go into a special GRASS folder which I unfortunately do not check often.
If you need something specifically from me, don't hesitate to email
me directly but be careful to edit the [GRASS5 part out of the subject
if it is related to a grass thread.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
