[GRASS5] [bug #2983] (grass) v.clean.html partly unreadable in
Konqueror
Hamish
hamish_nospam at yahoo.com
Sun Feb 13 16:38:51 EST 2005
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2983
> Subject: v.clean.html partly unreadable in Konqueror
> Platform: GNU/Linux/i386
> grass obtained from: Mirror of Trento site
> grass binary for platform: Compiled from Sources
> GRASS Version: grass-6.0.cvs_src_snapshot_2005_01_22
> The "What is a bridge?" section in v.clean.html is *completely*
> unredable in my Konqueror (KDE 3.2, Mandrake 10.1), while MS IE
> handles it fine. Maybe a drawing could be used instead of ASCII ART?
> If there are more ASCII ART entries in documentation they may suffer
> the same problem.
The problem is likely to be that you've set your monospace font to be
something that is a proportional font. If so, this a misconfiguration on
your machine, not a bug in v.clean.html.
g.manual -m v.clean
should help you out.
Hamish
