[GRASS5] FW: Need help with tcltk regexp - never mind
Michael Barton michael.barton at asu.edu
Tue Feb 15 01:45:38 EST 2005
As per my query below, I finally figured it out.
The GIS Manger in GRASS 6.0.1 can now have buttons to launch/select display
monitors.
____________________
C. Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
PO Box 872402
Arizona State University
Tempe, AZ  85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
------ Forwarded Message
> From: Michael Barton <michael.barton at asu.edu>
> Date: Sat, 12 Feb 2005 23:38:24 -0700
> To: grass devel <grass5 at grass.itc.it>
> Subject: Need help with tcltk regexp
> I'm trying to add a button bar to the GIS Manager with buttons to start/select
> display monitors. I've got it most of it done, but have hit a wall in a
> relatively simple test of whether or not a monitor is open and selected. I've
> used as a model, the procedure in d.m.tcl for the display button (which will
> display in the current monitor, and which while open monitor x0 if no monitor
> is open and selected).
> Here is my procedure. I hope someone can tell me why it is not working. I
> can't get it to recognize either of the regexp clauses. The variable mon can
> be set to values of x0, x1, x2, etc.
> Thanks in advance.
> Michael
> proc DmMonitorsel::displmon { mon } {
>     global dmpath
>     if ![catch {open "|d.mon -L" r} input] {
>         while {[gets $input line] >= 0} {
>             if {[regexp -nocase {$mon.*not running} $line buffer monitor]} {
>                 run "d.mon start=$mon"
>                 return
>             } elseif {[regexp -nocase {$mon.*running} $line buffer monitor]} {
>                 run "d.mon select=$mon"
>                 return
>             } else {
>                 return
> PO Box 872402
> USA
> Phone: 480-965-6262
> Fax: 480-965-7671
------ End of Forwarded Message
