[GRASS5] temp file permissions: 0666?
Tue Feb 15 07:33:54 EST 2005
Radim Blazek wrote:
> What does happen with umask in this case?:
>     execl ("/bin/sh", "sh", "-c", startup, 0);
The child inherits its umask from the parent.
> The problem appeares in DB drivers which create 0666 files even if umask
>   in shell is 0022. How to set umask correctly?
lib/db/dbmi_driver/driver.c:
	db_driver(int argc,
	    char *argv[])
	    int stat;
	    int procnum;
	    int i;
	    int rfd, wfd;
	    FILE *send, *recv;
	    umask(0);
Remove that umask() call.
