[GRASS5] Re: [bug #2990] (grass) v.surf.rst fails when called from GUI and in command-line mode
Helena hmitaso at unity.ncsu.edu
Wed Feb 16 00:01:43 EST 2005
guest user via RT wrote:
> re v.surf.rst GUI window failing from d.m menu.
> (Raster -> Interpolate -> Reg. Spline ..)
> The "Authors:" text needs to be moved to directly after the G_parser() call,
> otherwise it breaks the auto-generated GUI window.
Ok I will do it - Michael, you can ignore my comment regarding the GUI
thanks,
Helena
> Hamish
> -------------------------------------------- Managed by Request Tracker
