[GRASS5] fixed 2 bugs in GIS Manager GRASS 6
Helena Mitasova hmitaso at unity.ncsu.edu
Wed Feb 16 10:53:52 EST 2005
Paul Kelly wrote:
> On Wed, 16 Feb 2005, Michael Barton wrote:
> > This error is erratic. The most consistent way I've been able to reproduce
> > it and get v.surf.rst to work is the following:
> > It seems to choke on the line:
> > Authors: original version -  H.Mitasova, L.Mitas, I. Kosinovsky, D.P. Gerdes
> > See manual pages for reference and publications
> > This kind of output regularly causes programs called from the tcltk menus to
> > fail. I've futzed with it a bit and can't get it to run consistently. Can
> > you perhaps not have it try to display this to the xterm? It ought to run OK
> > then.
I have completely removed that line and it still gives the same error
GRASS 6.0.cvs:~/grasscvs6/grass6/vector/v.surf.rst >
ERROR: Required parameter <input> not set:
    (Name of the vector file with input data).
Helena
Description:
 Interpolation and topographic analysis from given point or contour data
in vector format to GRASS floating point raster format using regularized
spline with tension.
> Just a guess but perhaps in some places it writes to stdout and others to
> stderr? IMHO for messages like that that aren't part of the GIS-related
> output of the module, it should always be stderr: see
> http://grass.itc.it/pipermail/grass5/2004-October/015720.html
> Paul
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
