[GRASS5] fixed 2 bugs in GIS Manager GRASS 6
Helena Mitasova
hmitaso at unity.ncsu.edu
Wed Feb 16 12:06:15 EST 2005
It looks like it is trying to run the program BEFORE opening the
interface
that allows the user to give it the input file and other required
options - so it gives an error that it does not have input and then
displays the usage information - which is a correct behavior
(grass programs display usage if there is an error on command line).
So is there a way how to make it display the interface first, let the
user
type/select the input and other parameters and then run it?
I removed all stdout stuff from the program and it does not make a
difference.
Michael do you have the latest update of grass6 cvs on your desktop
where
the command starts correctly? If it is an older version I can try to
track any changes
that were made and see whether that would help.
The program runs fine on the command line.
Helena
Michael Barton wrote:
> Helena and others,
> This program (not the version that Helena just fixed) is launching fine from
> the menus on my desktop G5. It was launching erratically on my PowerBook
> last night. On my PowerBook, it wants to print all the help text to the
> terminal when I launch it. This is not happening on my desktop. Why? I have
> absolutely no idea.
> I think that Paul is on the right track, but there may be more to it than
> just the author citation. It should only print the usage/man page
> information from the command line with the -h switch. There is an
> undocumented gui flag that Glynn has described but that I can't find at the
> moment and I can't remember what it does. This might help (I'm a big help,
> yes?). At the moment, I'll keep the menu entry calling v.surf.rst as it is
> because I can't see changing it has any useful effects. However, if we can
> get some kind of consistent--proper--behavior I'll update the menu as needed
> to do this.
> Michael
> ______________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution and Social Change
> Arizona State University
> Tempe, AZ 85287-2402
> USA
> voice: 480-965-6262; fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
> > From: Helena Mitasova <hmitaso at unity.ncsu.edu>
> > Date: Wed, 16 Feb 2005 10:53:52 -0500
> > To: Paul Kelly <paul-grass at stjohnspoint.co.uk>
> > Cc: Michael Barton <michael.barton at asu.edu>, Hamish <hamish_nospam at yahoo.com>,
> > <grass5 at grass.itc.it>
> > Subject: Re: [GRASS5] fixed 2 bugs in GIS Manager GRASS 6
> > Paul Kelly wrote:
> >> On Wed, 16 Feb 2005, Michael Barton wrote:
> >>> This error is erratic. The most consistent way I've been able to reproduce
> >>> it and get v.surf.rst to work is the following:
> >>> It seems to choke on the line:
> >>> Authors: original version - H.Mitasova, L.Mitas, I. Kosinovsky, D.P. Gerdes
> >>> See manual pages for reference and publications
> >>> This kind of output regularly causes programs called from the tcltk menus to
> >>> fail. I've futzed with it a bit and can't get it to run consistently. Can
> >>> you perhaps not have it try to display this to the xterm? It ought to run OK
> >>> then.
> > I have completely removed that line and it still gives the same error
> > GRASS 6.0.cvs:~/grasscvs6/grass6/vector/v.surf.rst >
> > ERROR: Required parameter <input> not set:
> > (Name of the vector file with input data).
> > Helena
> > Description:
> > Interpolation and topographic analysis from given point or contour data
> > in vector format to GRASS floating point raster format using regularized
> > spline with tension.
> >> Just a guess but perhaps in some places it writes to stdout and others to
> >> stderr? IMHO for messages like that that aren't part of the GIS-related
> >> output of the module, it should always be stderr: see
> >> http://grass.itc.it/pipermail/grass5/2004-October/015720.html
> >> Paul
> >> _______________________________________________
> >> grass5 mailing list
> >> http://grass.itc.it/mailman/listinfo/grass5
