[GRASS5] [bug #3014] (grass) v.hull: work for all vectors, not just points
Request Tracker grass-bugs at intevation.de
Fri Feb 18 01:35:52 EST 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3014
Subject: v.hull: work for all vectors, not just points
v.hull only works when the input map contains points. It would be nice if you
could draw a polygon around the outer extent of vector lines or a series of
small polygons without having to run v.to.points first.
thanks,
Hamish
-------------------------------------------- Managed by Request Tracker
