[GRASS5] [bug #2997] (grass) v.in.ascii: add skip header lines option
guest user via RT grass-bugs at intevation.de
Fri Feb 18 12:14:36 EST 2005
... I have already implemented that:
RCS file: /grassrepository/grass6/vector/v.in.ascii/in.c,v
retrieving revision 1.19
diff -u -r1.19 in.c
--- in.c        8 Feb 2005 12:57:38 -0000       1.19
+++ in.c        18 Feb 2005 17:13:40 -0000
@@ -16,7 +16,7 @@
        struct Option *old, *new, *delim_opt, *columns_opt, *xcol_opt,
                *ycol_opt, *zcol_opt, *catcol_opt, *format_opt;
        int    xcol, ycol, zcol, catcol, format;
-       struct Flag *zcoorf, *t_flag, *e_flag;
+       struct Flag *zcoorf, *t_flag, *e_flag, *noheader_flag;
        char   *table;
        char   *fs;
        int    zcoor=WITHOUT_Z, make_table;
@@ -109,7 +109,11 @@
        e_flag = G_define_flag();
        e_flag->key              = 'e';
        e_flag->description      = "Create a new empty map and exit. Nothing
is read from input.";
+        noheader_flag = G_define_flag();
+        noheader_flag->key          = 'n';
+        noheader_flag->description  = "Don't expect a header when reading in
standard format";
        if (G_parser (argc, argv))
                exit(-1);
@@ -370,7 +374,8 @@
            fclose (tmpascii);
        } else {
             /* FORMAT_ALL = standard mode */
-           read_head(ascii, &Map);
+           if ( ! noheader_flag->answer )
+                   read_head(ascii, &Map);
            asc_to_bin(ascii, &Map) ;
To me it does not look intrusive. I can submit whenever
desired. Please suggest.
Markus
-------------------------------------------- Managed by Request Tracker
