[GRASS5] Re: [bug #3017] (grass) v.clean segfault
Radim Blazek
blazek at itc.it
Wed Feb 23 13:11:50 EST 2005
I fixed that, however:
1) bpol should be used as first cleaning tool, it does the same as
break, but it is faster on clean (identical boundaries) polygons
2) bpol works only with type=boundary, the same break,rmdupl etc.
Radim
Maciek Sieczka wrote:
>> Try to select the features causing segfault (repeated select half)
> Guilty is tool=bpol.
>> and send it to me.
> Please always specify your email. That makes replaying simplier as
> "Radim Blazek via RT <grass-bugs at intevation.de>" is a black hole.
> Maciek
> P.S.
> Thank you for taking care of this! (Although I'm aware you don't
> appreciate such "thank yous" too much ;)).
>> Radim
>> Request Tracker wrote:
>>> this bug's URL: http://intevation.de/rt/webrt?serial_num=3017
>>> Subject: v.clean segfault
>>> Platform: GNU/Linux/i386
>>> grass obtained from: Trento Italy site
>>> grass binary for platform: Compiled from Sources
>>> GRASS Version: grass-6.0.cvs_src_snapshot_2005_02_12
>>> I encounter a segfault with one particular dataset with the following
>>> options:
>>> GRASS 6.0.cvs:~ > v.clean input=i output=j type=area err=j_err
>>> tool=break,rmdupl,rmdac,bpol,rmarea
>>> | Tool | Threshold |
>>> | Break | 0.000000e+00 |
>>> | Remove duplicates | 0.000000e+00 |
>>> | Remove duplicate area centroids | 0.000000e+00 |
>>> | Break polygons | 0.000000e+00 |
>>> | Remove small areas | 0.000000e+00 |
>>> Copying vector lines ...
>>> Rebuilding parts of topology ...
>>> Building topology ...
>>> 407 primitives registered
>>> Topology was built.
>>> Number of nodes : 329
>>> Number of primitives: 407
>>> Number of points : 0
>>> Number of lines : 0
>>> Number of boundaries: 307
>>> Number of centroids : 100
>>> Number of areas : -
>>> Number of isles : -
>>> Tool: Break lines at intersections
>>> Intersections: 0
>>> Tool: Remove duplicates
>>> Duplicates: 0
>>> Building areas: 100%
>>> 100 areas built
>>> 22 isles built
>>> Attaching islands: 100%
>>> Attaching centroids: 100%
>>> Topology was built.
>>> Number of lines : 0
>>> Number of areas : 100
>>> Number of isles : 22
>>> Tool: Remove duplicate area centroids
>>> Duplicate area centroids: 0
>>> Tool: Break polygons
>>> Registering points ... 0
>>> All points (vertices): 0
>>> Registered points (unique coordinates): 0
>>> Points marked for break: 0
>>> Breaks: 0Segmentation fault
>>> Maciek
>>> -------------------------------------------- Managed by Request Tracker
>>> grass5 mailing list
>>> grass5 at grass.itc.it
>>> http://grass.itc.it/mailman/listinfo/grass5
>> --- Headers Follow ---
>>> From blazek at itc.it Mon Feb 21 08:40:10 2005
>> Return-Path: <blazek at itc.it>
>> Delivered-To: grass-bugs at lists.intevation.de
>> Received: from mail.intevation.de (aktaia [212.95.126.10])
>> by lists.intevation.de (Postfix) with ESMTP id D8C54102BCB
>> for <grass-bugs at lists.intevation.de>; Mon, 21 Feb 2005 08:40:10 +0100
>> (CET)
>> Received: from localhost (localhost [127.0.0.1])
>> by mail.intevation.de (Postfix) with ESMTP id 8DF2C36EDF
>> (CET)
>> Received: from mail.itc.it (ns.itc.it [217.77.80.3])
>> by mail.intevation.de (Postfix) with ESMTP id 1AE4836DC6
>> for <grass-bugs at intevation.de>; Mon, 21 Feb 2005 08:40:08 +0100 (CET)
>> Received: from ntmain.itc.it ([10.0.20.40])
>> by mail.itc.it (8.12.11/8.12.11) with SMTP id j1L7e7IN010683
>> for <grass-bugs at intevation.de>; Mon, 21 Feb 2005 08:40:07 +0100
>> Received: from orchestra.itc.it ([10.0.10.11])
>> by ntmain.itc.it (SMSSMTP 4.0.4.64) with SMTP id M2005022108400618391
>> for <grass-bugs at intevation.de>; Mon, 21 Feb 2005 08:40:06 +0100
>> Received: from itc.it (janacek [10.40.0.140])
>> by orchestra.itc.it (8.12.11/8.12.11) with ESMTP id j1L7e7Ng026616
>> Message-ID: <42199054.5050204 at itc.it>
>> Date: Mon, 21 Feb 2005 08:40:04 +0100
>> From: Radim Blazek <blazek at itc.it>
>> User-Agent: Mozilla/5.0 (X11; U; Linux i686; en-US; rv:1.6)
>> Gecko/20040113
>> X-Accept-Language: en-us, en
>> MIME-Version: 1.0
>> To: Request Tracker <grass-bugs at intevation.de>
>> Subject: Re: [GRASS5] [bug #3017] (grass) v.clean segfault
>> References: <20050219130424.66CF2102C28 at lists.intevation.de>
>> In-Reply-To: <20050219130424.66CF2102C28 at lists.intevation.de>
>> Content-Type: text/plain; charset=us-ascii; format=flowed
>> Content-Transfer-Encoding: 7bit
>> X-Spam-Status: No, hits=-4.9 tagged_above=-999.0 required=3.0
>> tests=BAYES_00
>> X-Spam-Level:
