[GRASS5] [bug #3023] (grass) r.fillnulls doesn't work
Maciek Sieczka werchowyna at pf.pl
Wed Feb 23 18:31:05 EST 2005
Subject: Re: [GRASS5] [bug #3023] (grass) r.fillnulls doesn't work
>> this bug's URL: http://intevation.de/rt/webrt?serial_num=3023
>> Subject: r.fillnulls doesn't work
> (works fine for me on 6.0beta2)
>> GRASS Version: grass-6.0.cvs_src_snapshot_2005_02_12
>> I'm reffering here to a single 3" SRTM tile loaded using r.in.srtm.
>> r.fillnulls works very long and uses so much swap that mouse stops
>> answering, temporarily, after several minutes.
> at which point in the script? Here it takes a couple minutes to run,
> long part is duing the v.surf.rst step but no runaway memory issues.
> run "top" in another window to watch what is going on?
> What is your region set to?
> try 'g.region rast=(map)' first?
I did it of course:
GRASS 6.0.cvs:~ > g.region rast=N51E016 -ap
projection: 3 (Latitude-Longitude)
zone:       0
datum:      wgs84
ellipsoid:  wgs84
north:      52:00:01.5N
south:      50:59:58.5N
west:       15:59:58.5E
east:       17:00:01.5E
nsres:      0:00:03
ewres:      0:00:03
rows:       1201
cols:       1201
Regarding the memory runaway:
- at 20% r.fillnulls starts using swap.
- at 93% the swap is full and mouse hardly responses until done; this is the
longest part.
- it doesn't run that long as I thought - 6 minutes alltogether
My system: RAM 512 MB, SWAP 2.0 GB, plenty of free disk space, Athlon XP
1.6, Mandrake 10.1, kernel 2.6.8.
>> Several error infos are printed (see below) and finally r.fillnulls
>> fails to produce anything - in spite of claiming to have "Filled
>> raster map is: N51E016_flnull".
>> Details:
>> r.fillnulls input=N51E016 output=N51E016_flnull tension=40. smooth=0.1
>> Using tmp file r_fillnulls_5276
>> Locating and isolating NULL areas...
>> r.buffer: 00000000 - illegal distance specification
> what is the output of "g.region -gm" ??
GRASS 6.0.cvs:~ > g.region -g
n=52.00041667
s=50.99958333
w=15.99958333
e=17.00041667
nsres=0.00083333
ewres=0.00083333
What is yours?
> I've just added some more error checking in CVS, can you update and try
> again? > maybe uncomment "echo RES=.." line?
> (It won't fix your problem but will stop the script if this step fails.)
I can't access CVS at home, my expensive, 2kB/s connection doesn't let me
to. But I'll grab the next CVS snapshot at my Uni.
> - In the script we should temporarily zoom to the raster limits with
> g.region first?
Not really a good idea I guess. Anytime it should be up to the user what
region he wants to patch.
> - I wonder if we should look at using a bigger r.buffer/r.grow area to
> get the slope etc at the edges of the hole a bit more correct?
Sounds reasonable to me.
On thing more: my bug report was based r.fillnuls in GUI mode. After running
it from the command line I see there are two more errors. Let me quote them
all now:
1.
invalid map: r_fillnulls_5276.buf
Syntax error
2. (the "new" one)
dbmi: Protocol error (invalid table/column name or unsupported column type)
3. (the second "new" one)
ERROR: Cannot insert new row: insert into vecttmp_fillnulls_4559 values
       (1376152, 208, '')
4.
ERROR: Cannot open old vector vecttmp_fillnulls_4559 at PERMANENT on level 2
5.
WARNING: coor files of vector 'vecttmp_fillnulls_4559 at PERMANENT' is larger
         than it should be (39908422 bytes excess).
ERROR: You first need to run v.build on vector file
       <vecttmp_fillnulls_4559>
6.
r.patch - rfillnulls_r_fillnulls_4559 not found
WARNING: Table 'vecttmp_fillnulls_4559' linked to vector did not exist.
(BTW: This is badly annoying that the eventuall error information is
different in GUI and comamnd line.)
After after zooming into a small region...
GRASS 6.0.cvs:~ > g.region -m
n=51.5375
s=51.485
w=16.17833333
e=16.2425
nsres=92.71504003
ewres=57.85284109
...only the error no 1. persists:
invalid map: r_fillnulls_5974.buf
Syntax error
And the r.fillnulls manages to output the filled DEM properly (I guess) in
spite of it.
Maciek
