[GRASS5] [bug #3028] (grass) how to places an EPS in a ps map
Radim Blazek blazek at itc.it
Thu Feb 24 12:42:52 EST 2005
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=3028
> Subject: how to places an EPS in a ps map
> I want to put an EPS in a PS map so I put in the instruction file:
> eps 0% 0%
> 	epsfile /home/jbc5/Imprimir_GRASS/eps/par157.eps
> 	scale 1
> 	rotate 0
> 	masked n
> end
> I have a problem with its situation, I have tried with UTM coordinates and
> with % but I don't know the reference point of my EPS. My EPS file is a
> little figure in one corner of a a4, where is the point of reference? in the
> figure? out the figure? the figure have coordinates? because I don't
> understand the place where the EPS appears in the PS map.
> Thanks,
> Lourdes
I think that reference points is center of bounding box.
If you need map coordinates, you have to use vpoints/eps.
Radim
