[GRASS5] nviz bug
Paolo Cavallini cavallini at faunalia.it
Mon Feb 28 02:28:49 EST 2005
If the problem is reproducible (please test it), and the command is not
particularly useful, as it appears to be the case, could you please remove it
before 6.0? It gives a very bad crash.
Thanks.
pc
At 20:00, sabato 26 febbraio 2005, Paul Kelly has probably written:
> On Sat, 26 Feb 2005, Paolo Cavallini wrote:
> > 3. dumping to IRIS RGB crashes X badly (BTW, is this an useful command?
> > Could be safely removed?).
> If you removed it then you could remove the copy of the libimage library
> in the GRASS source code (AFAIK only used for producing RGB files,but
> perhaps it is outdated and simply needs upgraded?). If it was to be
> removed then the makefiles could be changed to make RGB output only
> possible on systems that already havelibimage (like IRIX).
> Paul
Paolo Cavallini
cavallini at faunalia.it   www.faunalia.it   www.faunalia.com
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy   Tel: (+39)348-3801953
