[GRASS5] nviz bugs?
Markus Neteler
neteler at itc.it
Mon Feb 28 08:41:42 EST 2005
On Sun, Feb 27, 2005 at 06:00:55PM -0500, Helena wrote:
> I have been testing nviz using grass6 updated today and I noticed few
> problems:
> - label and legend do not redraw, Bob, are you around to check that, it
> used to work
solved.
> - nviz does not load vector points when given on command line or when called
> from GIS manager - it gives error "no lines fileneame found...."
> it is possible to load the points in nviz through "vector points" panel,
> so it is not critical, but it may be confusing to users.
Probably we have to have two parameters to load vector maps on CMD line?
> - the mkdspf pannel should be removed - it does nothing
I have removed it, but don't know if I have to modify
scripts/tclIndex
as well. Please suggest (or, better fix directly in CVS).
Then, what about
src/mkdspf_iso_surface.c
src/mkdspf_main.c
? To be removed as well?
Markus
