[GRASS5] NVIZ - more bugs
Helena
hmitaso at unity.ncsu.edu
Mon Feb 28 09:13:22 EST 2005
peter.loewe at gmx.de wrote:
> Dear all:
> NVIZ in GRASS 6beta2 (built from source) still contains the
> strange coloring bug regarding 3d-site-vectors:
> When such vectors are displayed atop raster data, everything is
> fine at first sight. However, any manipulation requiring a redraw
> renders the image pitch-black. Setting the lighting to max shows
> that the color used for the sites is somehow "draped" over the
> landscape + the weird darkening effect.
> This bug prevents any serious use of 3d-sites, except for "gothic
> GIS" if there is such a thing.
> Peter
Peter, I tried it yesterday with the 3D site file that is in the demo
data set slovakia - it worked fine - both when draped and when displayed
as 3D. Can you try it with the slovakia data set
(remeber to load it as vector points from nviz interface, not vector
from command line) and see whether it works? If yes, we need to look at
your data to see what is different,
Helena
