[GRASS5] [bug #2991] (grass) NVIZ fails to display 3D polygons
Markus Neteler neteler at itc.it
Mon Feb 28 12:03:19 EST 2005
On Mon, Feb 14, 2005 at 08:43:43PM +0100, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2991
> Subject: NVIZ fails to display 3D polygons
> Platform: GNU/Linux/i386
> grass obtained from: Mirror of Trento site
> grass binary for platform: Compiled from Sources
> GRASS Version: grass-6.0.cvs_src_snapshot_2005_01_22
There was a related fix in lib/ogsf/
2005-02-03 15:28  markus
        * Gv3.c: fix for areas, now 2D polygons visible as boundaries again
        (3D areas should be visible as filled polygons)
> NVIZ doesn't display 3D polygon properly. Visualisation with 3D polygons is impossible.
Please try with a newer GRASS 6 version.
Hope this helps
 Markus
