[GRASS5] [bug #2885] (grass) g3d region problem
Radim Blazek
blazek at itc.it
Wed Jan 5 11:03:20 EST 2005
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2885
> Subject: g3d region problem
> Platform: GNU/Linux/i386
> grass obtained from: Trento Italy site
> grass binary for platform: Compiled from Sources
> GRASS Version: 5.7 weekly snapshot: 12-25-04
> g3d-files appear to be immune to changes to the current region made by
> d.zoom
> example: A g3d-file is created from several rasters in a location (including
> setting the r3-parameters for g.region). Then the current region is modified
> by zooming in using d.zoom.
> When NVIZ is now called up, the 2d-region settings are as to be expected,
> yet the 3d-volume settings are way up in limbo: strange volumes (from outer
> space?) roam the skies.
> a workaround is to recreate the g3d-file after each zooming-step.
> Cheers,
> Peter Loewe
The problem is in NVIZ or in the module creating the raster 3D?
Can you post the output from?:
g.region -p3
r3.mapcalc "test=1"
r3.info test1
Radim
