[GRASS5] [bug #2889] (grass) i.rectify doc comments
Request Tracker grass-bugs at intevation.de
Wed Jan 5 15:47:55 EST 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=2889
i.rectify comments
   By selecting the 1st ORDER option, the user may select the order of
Don't say 1st. Say X or something.
   transformation desired: Select order of transformation --> 1st
   Order 2nd Order 3rd Order
   The program will immediately recalculate the RMSE and the number of
   points required.
  Linear affine transformation (1st order transformation)
          x' = ax + by +c
          y' = Ax + Bt +C
   The a,b,c,A,B,C are determined by least squares regression based on
   the control points entered.  This transformation applies scaling,
   translation and rotation. It is NOT a general purpose
   rubber-sheeting, nor is it ortho-photo rectification using a DEM,
say what to use for those
   not second order polynomial, etc.  It can be used if (1) you have
   geometrically correct images, and (2) the terrain or camera
   distortion effect can be ignored.
there should be a way to rectify with just two points BTW.
PS: there should be a way to on the monitor show point numbers next to points in
a group/xxx/POINTS file.
--- Headers Follow ---
>From jidanni at jidanni.org  Wed Jan  5 21:47:54 2005
Return-Path: <jidanni at jidanni.org>
Delivered-To: grass-bugs at lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
	by lists.intevation.de (Postfix) with ESMTP id CFEB710015D
	for <grass-bugs at lists.intevation.de>; Wed,  5 Jan 2005 21:47:54 +0100 (CET)
Received: from localhost (localhost [127.0.0.1])
	by mail.intevation.de (Postfix) with ESMTP id 7303636DE2
Received: from frodo.hserus.net (frodo.hserus.net [204.74.68.40])
	by mail.intevation.de (Postfix) with ESMTP id C7E0F36CD8
	for <grass-bugs at intevation.de>; Wed,  5 Jan 2005 21:47:52 +0100 (CET)
Received: from tc218-187-79-109.2-4.dynamic.apol.com.tw ([218.187.79.109]:32787 helo=jidanni1)
	by frodo.hserus.net with esmtpsa
	(Cipher TLSv1:RC4-SHA:128) (Exim 4.43 #0)
	id 1CmI4E-0001YI-25 by authid <jidanni> with plain
	for <grass-bugs at intevation.de>; Thu, 06 Jan 2005 02:17:44 +0530
To: grass-bugs at intevation.de
Subject: i.rectify doc comments
Date: Thu, 06 Jan 2005 02:41:48 +0800
Message-ID: <87zmznhg5v.fsf at jidanni.org>
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
X-Spam-Status: No, hits=-4.9 tagged_above=-999.0 required=3.0 tests=BAYES_00
X-Spam-Level:
-------------------------------------------- Managed by Request Tracker
