[GRASS5] [bug #2891] (grass) i.points: mention how to remove or change an undesired point
Request Tracker
grass-bugs at intevation.de
Wed Jan 5 15:49:21 EST 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=2891
i.points.html should mention how to remove or change an undesired
point, now while entering points, and later, from the previously
written file.
Also maybe there should be a documented way to manipulate the
"status (1=ok)"
field of group/xxx/POINTS files, to "temporarily deactivate points" too.
--- Headers Follow ---
>From jidanni at jidanni.org Wed Jan 5 21:49:20 2005
Return-Path: <jidanni at jidanni.org>
Delivered-To: grass-bugs at lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
by lists.intevation.de (Postfix) with ESMTP id E4ACD10015D
for <grass-bugs at lists.intevation.de>; Wed, 5 Jan 2005 21:49:20 +0100 (CET)
Received: from localhost (localhost [127.0.0.1])
by mail.intevation.de (Postfix) with ESMTP id B73DD36DEF
Received: from frodo.hserus.net (frodo.hserus.net [204.74.68.40])
by mail.intevation.de (Postfix) with ESMTP id 34E1A36CD8
for <grass-bugs at intevation.de>; Wed, 5 Jan 2005 21:49:20 +0100 (CET)
Received: from tc218-187-79-109.2-4.dynamic.apol.com.tw ([218.187.79.109]:32787 helo=jidanni1)
by frodo.hserus.net with esmtpsa
(Cipher TLSv1:RC4-SHA:128) (Exim 4.43 #0)
id 1CmI5m-0001YI-5P by authid <jidanni> with plain
for <grass-bugs at intevation.de>; Thu, 06 Jan 2005 02:19:18 +0530
To: grass-bugs at intevation.de
Subject: i.points: mention how to remove or change an undesired point
Message-Id: <E1CmDyJ-0000bc-Dz at jidanni1>
Date: Thu, 06 Jan 2005 00:25:19 +0800
X-Spam-Status: No, hits=-4.5 tagged_above=-999.0 required=3.0 tests=BAYES_00,
DATE_IN_PAST_03_06
X-Spam-Level:
-------------------------------------------- Managed by Request Tracker
