[GRASS5] 3D flyover from DEM?
David Piasecki
piasecda at nv.doe.gov
Thu Jan 6 13:03:16 EST 2005
Thanks. I'll give that a try.
David
On Jan 6, 2005, at 9:48 AM, Michael Barton wrote:
> I think that you can save the animation files from NVIZ in a format
> you can
> use in another app.
> Michael
> On 1/6/05 10:45 AM, "David Piasecki" <piasecda at nv.doe.gov> wrote:
>> Do I have to use the NVIZ viewer separate from my own application, or
>> is there a way to view the data with OpenGL?
>> David
>> On Jan 6, 2005, at 9:21 AM, Michael Barton wrote:
>>> This can be done in NVIZ--including the animated flyover.
>>> Michael
>>> On 1/5/05 11:16 AM, "David Piasecki" <piasecda at nv.doe.gov> wrote:
>>>> Aside from simply setting a point of reference and drawing a static
>>>> map
>>>> based on a DEM, is there a way to generate a 3D map which I can use
>>>> as
>>>> some sort of fly-over? In other words, with a DEM and a 2D image
>>>> overlaid on top, I'd like to generate a file that I can use in a 3D
>>>> viewer (perhaps Quicktime or something similar) which enables me to
>>>> zoom in and out and change my point of reference without going back
>>>> to
>>>> GRASS to redraw.
>>>> Thanks,
>>>> David
>>> ______________________________
>>> Michael Barton, Professor of Anthropology
>>> School of Human Evolution and Social Change
>>> Arizona State University
>>> Tempe, AZ 85287-2402
>>> USA
>>> voice: 480-965-6262; fax: 480-965-7671
>>> www: http://www.public.asu.edu/~cmbarton
> USA
