[GRASS5] Re: [GRASSLIST:5282] v.out.ascii Segfault -- backup plan?
Jachym Cepicky jachym.cepicky at centrum.cz
Tue Jan 11 03:36:32 EST 2005
Confirm, it run's all right now.
Thank you a lot .. a vubec fakt MOC dik, a preju hezkej den
Jachym
On Tue, Jan 11, 2005 at 09:28:49AM +0100, Radim Blazek wrote:
> Fixed. Update and recompile vector/v.out.ascii.
> Radim
> Jachym Cepicky wrote:
> >ahoj,
> >>>GRASS 5.7.cvs:~ > echo "-592854.20115798|-1149140.62500086"| v.in.ascii
> >>>out=tmp
> >>>GRASS 5.7.cvs:~ > v.out.ascii tmp
> >>>Segmentation fault
> >>>GRASS 5.7.cvs:~ >
> >>>The complete strace output from "v.out.ascii tmp" can you find on
> >>>www.fle.czu.cz/~jachym/tmp/strace.txt
> >>Can you send a back trace from gdb?
> >>Radim
> >I hope, this is what you want, if not, describe please, how to get what you
> >want:
> >GRASS 5.7.cvs:~ > gdb --args v.out.ascii tmp
> >GNU gdb 6.1-debian
> >Copyright 2004 Free Software Foundation, Inc.
> >GDB is free software, covered by the GNU General Public License, and you
> >are
> >welcome to change it and/or distribute copies of it under certain
> >conditions.
> >Type "show copying" to see the conditions.
> >There is absolutely no warranty for GDB.  Type "show warranty" for details.
> >This GDB was configured as "i386-linux"...Using host libthread_db library
> >"/lib/tls/i686/cmov/libthread_db.so.1".
> >(gdb) run
> >Starting program: /usr/local/grass-5.7.cvs/bin/v.out.ascii tmp
> >[Thread debugging using libthread_db enabled]
> >[New Thread 1089834368 (LWP 4888)]
> >Program received signal SIGSEGV, Segmentation fault.
> >[Switching to Thread 1089834368 (LWP 4888)]
> >0x4056114b in strlen () from /lib/tls/i686/cmov/libc.so.6
> >(gdb) bt
> >#0  0x4056114b in strlen () from /lib/tls/i686/cmov/libc.so.6
> >#1  0x4045c15d in G_store (s=0xffff <Address 0xffff out of bounds>)
> >    at store.c:20
> >#2  0x40039c79 in Vect__open_old (Map=0xbffff2f0, name=0x80609e8 "tmp",
> >    mapset=0xffff <Address 0xffff out of bounds>, update=0, head_only=0)
> >    at open.c:148
> >#3  0x4003a6e9 in Vect_open_old (Map=0xbffff2f0, name=0x80609e8 "tmp",
> >    mapset=0xffff <Address 0xffff out of bounds>) at open.c:375
> >#4  0x080497bb in main (argc=2, argv=0xbffff7d4) at out.c:67
> >(gdb)
> >Jáchym
Jachym Cepicky
e-mail: jachym.cepicky at centrum.cz
URL: http://les-ejk.cz
GPG: http://www.fle.czu.cz/~jachym/gnupg_public_key/
Name: not available
Desc: Digital signature
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20050111/0a8fb35b/attachment.bin
