[GRASS5] Re: [GRASSLIST:5319] Compilation error in r.mapcalc
Radim Blazek
blazek at itc.it
Wed Jan 12 12:30:40 EST 2005
Thanks, fixed but the bug is in 6.0.0 beta1.
Radim
Tom Russo wrote:
> I'm running Grass5.7 on FreeBSD 4.x, which still uses GCC 2.95. When I updated
> today and tried to build I got a compilation error in r.mapcalc. Turns
> out that in Monday's commit to map3.c, a variable declaration was inserted
> after the first executable line in a block --- something that GCC 2.95
> considers a syntax error but GCC 3.x does not.
> The attached patch fixes it by moving the declaration of "handle" before
> the call to setup_region.
> Could someone commit this?
> Index: map3.c
> RCS file: /home/grass/grassrepository/grass51/raster/r.mapcalc/map3.c,v
> retrieving revision 2.2
> diff -u -u -r2.2 map3.c
> --- map3.c 10 Jan 2005 17:23:46 -0000 2.2
> +++ map3.c 12 Jan 2005 16:58:47 -0000
> @@ -497,8 +497,9 @@
> mapset = G_find_grid3(tmpname, "");
> if (mapset)
> + void *handle;
> setup_region(); /* TODO: setup_region should be called by evaluate() ? */
> - void *handle = G3d_openCellOld(
> + handle = G3d_openCellOld(
> tmpname, mapset, ¤t_region3,
> G3D_TILE_SAME_AS_FILE, G3D_NO_CACHE);
> result = (G3d_fileTypeMap == G3D_FLOAT)
