'd.vect display=attr' without attrcol= option gives a warning: WARNING: attrcol not specified, cannot display attributes and then adds itself to the monitor's command list. (so you get the same warning everytime you do d.redraw) Any reason for this not to be changed to G_fatal_error()? Hamish
