[GRASS5] d.m problem grass 6.0.0.0 beta1
Michael Barton
michael.barton at asu.edu
Sun Jan 16 13:28:24 EST 2005
Soren,
I cannot reproduce this error. I just tried GRASS 6.0.0 beta1 on my Mac OSX
using the Spearfish demo set. Display raster works without problems from the
GIS Manager (d.m) if no options are selected, if either overlay or legend
are selected, or if both overlay and legend are selected.
I have a question. Do you have a saved workspace/dm file that you have
opened and are trying to displaying?
There is a minor bug that I've never reported that happens if I save a
workspace, quit GRASS, restart GRASS later, and reopen the workspace. I get
strange errors like this unless I 'touch' each file name in the GIS Manager
list. That is, I have to click on each item in the display manager panel,
then click on the box below (raster or vector panel) that contains the name
of the file being displayed. By putting the mouse focus on this input box it
somehow 'activates' the file correctly. After doing this once in a session,
this set of maps displays fine.
Could this be what is happening to you?
Michael
On 1/15/05 9:58 AM, "Soeren Gebbert" <soeren at pool.math.TU-Berlin.DE> wrote:
> Dear developers ive just compiled grass60 successfully but when i am using
> d.m and want to visualize a raster map, i get this error:
> can't read "opt(1,legend)": no such element in array
> while executing
> "if { $opt($id,legend) } {
> set cmd "d.rast.leg map=$opt($id,map)"
> (procedure "DmRaster::display" line 19)
> invoked from within
> "DmRaster::display $node"
> ("raster" arm line 2)
> invoked from within
> "switch $type {
> group {
> DmGroup::display $node
> raster {
> labels {
> DmLabels::display $node
> (procedure "Dm::display_node" line 6)
> invoked from within
> "Dm::display_node $n"
> (procedure "DmGroup::display" line 11)
> invoked from within
> "DmGroup::display $node"
> ("group" arm line 2)
> invoked from within
> "switch $type {
> group {
> raster {
> labels {
> invoked from within
> invoked from within
> "DmGroup::display "root""
> (procedure "Dm::display" line 6)
> invoked from within
> "Dm::display"
> ("uplevel" body line 1)
> invoked from within
> "uplevel \#0 $cmd"
> (procedure "Button::_release" line 18)
> invoked from within
> "Button::_release .mainframe.topf.tb0.bbox1.b0"
> (command bound to event)
> I didnt used the option "display with legend" and this error disapears if
> i created a legend (d.m command button) "d.legend map=Geologie_final
> color=black at=5,30,80,95 -c use=2,3,4,5,6,7,8,9", so what did i wrong?
> Should i always create a legend to display a raster map?
> Best regards
> soeren
____________________
C. Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
