On Fri, Jan 21, 2005 at 03:01:16PM +1300, Hamish wrote: > The d.slide.show script will not run. Here is does. Strange... > chmod a+x scripts/d.slide.show/d.slide.show > > fixes it, but how do you check a permission change into CVS? This should not be necessary as include/Make/Script.make takes care (maybe not on your platform?) Markus
